Trying to identify injectors and chip!
Djed710
Hi, I need to determine what chip my cossie is running so I can find out what the boost should be set to! The injectors are yellow and have 1137/02 printed on one side and f0367 on the other side. The chip has torbosystems motorsport printed on it and l6 fr6 I.c 18.12.97 written on in pen. Any ideas?! Thanx
Djed710
Hi Mate thanx, it's got a -31 actuator already fitted and with the the Amal valve piped in like it should be it runs at just under 1.5bar but sumtimes drops it too 1bar (I presume that's the Amal valve doing it's thing!) is 1.4 about 17psi like you say? I thought 1bar was about the max u could run on stage 1 that's why I was a bit worried about it running lean. I dnt no the history of the car and what's been done so trying to work out what stage it's at. Thanx again.
mk3ste
17-10-2021 10:09 AM
