Brake Pedal Kicks Back!
Old 07-07-2011, 10:10 PM
Heathen
Heathen's Avatar
Location: A Small Island Somewhere In The South Pacific
Default Brake Pedal Kicks Back!
Finally got my car back on the road (legally).
However, my ABS warning light is on all the time. I swapped the ABS computer with another one I had in my shed. That cured the problem, but a week later the light came back on.
Now when i press down on the brake pedal, I can feel it press back on my foot...I think more so when it is cold.
Any ideas?
Thanks.
Old 07-07-2011, 10:11 PM
dojj
Resident Wrestling Legend
dojj's Avatar
it's the abs kicking in because one of the sensors is dirty
Old 08-07-2011, 12:04 AM
kosienutter
Last Time, Get Off PF FFS
kosienutter's Avatar
2nd that. I have the same on my o/s front sensor but I can't get it out at the mo because it has wedged itself in the hub so tryin to think of ways to get it out to clean it lol.
Old 08-07-2011, 12:19 AM
ST24MK2
ST24MK2's Avatar
Mine does that, if im braking and go over a bump in the road the pedal grinds and kicks back?
Old 08-07-2011, 12:24 AM
kosienutter
Mine only does it below 10 mph as above the abs doesn't see what ever is causing my abs feedback
Old 08-07-2011, 12:21 PM
It can also be caused by rust build up on the rear driveshaft rings for the abs, if a loose bit of rust flakes is across the gap it causes issues.
Old 08-07-2011, 12:23 PM
RichieST
RichieST's Avatar
As above, I had this on an old car, I cleaned the sensors and rings up which cured it for a while but it did come back. As a new sensor cost more than the car was worth I just pulled the ABS fuse and took the bulb out the dash!
Old 08-07-2011, 12:38 PM
martysmartie
martysmartie's Avatar
It's as said a dirty sensor or ring gear, mine has always done this at low speed just before coming to a stop. Mine is caused by the O/S front sensor, I have the same problem as above I can't get it out so left it, but I will have an another look soon.
It won't necessarily illuminate the ABS light as that only comes on when part of the system is inoperative so far as I know, so if the ABS system is told incorrectly there is a discrepancy in wheel speed it will activate the ABS.
Martin
Old 08-07-2011, 12:39 PM
martysmartie
Trouble is by doing this the car won't pass an MOT, I wouldn't buy one of the sensors new due to the rip off prices, last one I got was from another car.
Martin
Old 08-07-2011, 12:45 PM
RichieST
RichieST's Avatar
I wasn't keeping the car anyway, sold it to a mate of mine, who promptly wrote it off 3 days later
Old 08-07-2011, 06:06 PM
They don't need to be cossie abs sensors, or even abs sensors, any hall effect sensor of the correct value/resistance can be used, that can be made to fit.
Old 08-07-2011, 06:15 PM
botters
competant bodger
botters's Avatar
i had this problem on my car i just disconnected the two pin plug on the brake fluid cap to disable the system as you dont really need abs anyway, i might get round to fixing it one day lol
original
30-01-2022 08:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
Quick Reply: Brake Pedal Kicks Back!
