3dr cosworth rally tarmac spring lbs??
The `87 Specification Sheet for Lovell/McRae/Auriol says:
Front: 500 lbs/in Springs 280 mm (Dampers 320/100 or 325/125, Bump 50mm)
Rear: 212 lbs/in Springs 355mm (Dampers 260/90, Bump 50 mm)
Castor: 4 deg, Camber 3 deg, toe in 15`in, Ride Height 200 mm
Supposed to be Bilstein-Dampers...and where do you think a 355 mm long rear spring would fit?
ARB were bladed-type (in full stiff position) with 1 in diameter, 10 SWG (or 1.1 in with 14 SWG) front and 3/8 in 14 SWG rear
matman
09-09-2015 05:45 PM
Marc sierra
12
30-08-2015 10:38 AM
