Stronger cam belt?
Stronger cam belt?
Is there a stronger one on the market as I have recently changed mine and now its stripped the teeth off down by the crankshaft pulley, and I wasn't caning it either
I had alloy camshaft pulleys on my engine. The teeth edges became sharp and weakened the cam belt teeth, and the belt teeths where then ripped off by the crankshaft pulley. The belt is not the problem, most likely the pulleys are.
No everything is stock my only observation, as seen in another thread, was the belt tightening up lots when hot but loose as hell when cold, I thought it must be a cheap jack belt but I got it from Cosworth USA
Sadly getting stuff from cosworth these days doesn't mean a thing quality wise, they produce or rather supply some real shit these days, just look at their oil pumps that explode.
I do mine every three years, or 25,000, so usually before 3 years.
I use DAYCO belt kit, the belt is gates under license, the tensioner is INA canada, not had any problems.
Mc5506
05-10-2015 09:57 PM
