ive told him to get some siemens and then get it set up will be so much better
Why's that then ?
Siemens may be easier to map, but having seen many many cars on siemens, and siemens and bosch injectors being flowed there is nothing that jumps out as different, if mapped to it's FULL potential and that's a big IF with an off the shelf chip I seriously doubt you'd see a difference between the two.
I'd say about 320bhp, slightly less torque, I get 300bhp from a T3-34.48, my hybrid runs a T34 trim in a std T3 comp housing, with a .48 turbine.
Your spec will make a excellent punchy road car with good manners.
Get a set of light blues (400) and get a chip to suit that with the boost about 30psi same setup as i had before car felt awsome and used to piss past my mates with your set up!!
to be honest it ran a 13.3 quarter at 108 so im quite happy as it is for now because it drives perfect but il do what mark shead told me then i may have it live mapped at nms
Dedicated 1 on 1 mapping will be money very well spent, it will really get the best from the car, even better when done on rollers and not road imo.
