Removing standard air filter to fit cone filter
I'm removing my standard air filter box to fit a cone filter. What do I have to do about the hose connected to it that comes from the little breather box thing below the inlet manifold?
That is your breather outlet, I have seen the original hose plumbed into the back of the cone filter, however it coats the filter in oily muck. I have also seen a breather filter put on the outlet at the manifold, but thats not ideal either. Best bet in the long run is a breather/seperator plumbed in.
What boost is she running?
Totally standard at the moment but will eventually be hoping for around 300-330bhp on greens, chip, -31 and a T34 so will be running whatever boost is needed for that.
How do the separators work then? And where does it redirect the fumes etc to?
There's a few variations on the theme of breather, but basically all work the same by taking all the engine pipes where pressure comes out to a cylinder/chamber, then sometimes onto a air filter, a lot are vented to the atmosphere, some have filters in the end parts, some are very expensive overpriced bits that are crap some aren't, not a hard diy thing to make if you have the tools.
What would you recommend me to do then? Buy a Bailey breather kit? I didn't really want any of those aluminium pots and stuff under the bonnet but obviously I'll have to do something with this hose when I fit the cone filter.
You can get less intrusive breather systems than the bulky ones that are all bling, a breather is a breather, look on ratsport.co.uk for inspiration, personally I wouldn't encourage anyone to buy a bailey breather, but each to their own and all that.
Thanks but I've already bought a filter, so if I decide to go down the route of keeping the breather venting into the intake system then I shall just drill the one I've got.
track.focus'd
12-08-2015 05:53 PM
Escortdriver1
05-08-2015 12:45 PM
