wire for oil pressure switch
Old 06-06-2011, 09:54 AM
Marc sierra
Marc sierra's Avatar
Default wire for oil pressure switch
Can anyone tell me where the wire for the oil pressure switch is on a (LHD) cossie 4x4? In What part of the loom is it, injectors, starter motor, or somewhere else? The car has the wire disconnected as it has a remote oil pressure sensor fitted, but I also want to connect the oil pressure switch.
Old 06-06-2011, 12:24 PM
martysmartie
martysmartie's Avatar
It's part of the car loom, and leaves the loom with the starter solenoid wire, it's green and another colour, if you are wanting both you will need a t piece adapter to connect them.
Martin
Old 06-06-2011, 12:44 PM
g10ens
g10ens's Avatar
It's green and brown on a 3dr, possibly the same colour on yours.
Old 06-06-2011, 01:44 PM
siscossie
3-door moonstone
siscossie's Avatar
Does it have a positive ignition feed to it?
Old 06-06-2011, 05:38 PM
martysmartie
Yes it's a switched live feed and the switch supplys the ground.
Martin
Old 06-06-2011, 07:35 PM
Marc sierra
Yes, it should be brown/green. I checked from the top and also from underneath, but I can't find such a wire coming from the same part of the engine loom as the starter motor wires.
I'll probably put an additional wire in from behind the clocks to the external pressure switch I have, then the problem is also solved.
Old 06-06-2011, 08:24 PM
martysmartie
Some numptys probably cut it.
Martin
dombanks
21-09-2015 08:38 PM
xrmalin
13-09-2015 06:52 PM
hopper350
04-09-2015 12:53 AM
CrOwSoN15
14
03-09-2015 12:21 PM
Quick Reply: wire for oil pressure switch
