Oil Temp and Pressure Sensor Placement - 2wd saph
other than having something drilled and tapped into my sump for a temp sensor ( which i dont really want to do), i have a magnetic sump plug so cant use and adaptor like i was planning to, so where else would be best to get a temp reading from?
i had the idea of using a 4x4 filter re-location arm sandwich with a sandwich plate for both pressure and temp, this be any good?
any other suggestions?
back to the drawing board for the temp sensor then
only mentioned the sandwich plate as i have it sitting at home doing sweet fa so thought id try see if i could get some use out of it
i did buy an adaptor for the drain plug but i bought a magnetic sump plug and i'm using that instead now, so need to find somewhere else to fit it
yeah you sensor is a little out of the way
You can put it in the gallery where the oil pressure switches are mate, but it's all about getting the temp sensor into the flow of the oil, to get an accurate reading if you put it there. You'd need say a 3mm thermocouple, and put it around 2mm into the flow of the oil
I'd have temp in the sump and pressure where the original sensor is. Oil in the sump is typically hotter than the gallery[/QUOTE]
The oil around the outer edges inside the sump will be COOLER, as aluminum is ace at heat transfer, when in the gallery it absorbs heat from surrounding metal.
i'm assuming the reading wont be as accurate to those given if the sensor was in the sump?
The reading will be 100% accurate for the oil where the sensor is, as here it has already been squeezed by the pump and made contact with hot engine surfaces it will have picked up heat, part of the oils job.
Personally my fave place in in the sump, mine maintained for example 80C today when measured from the sump, which is the coolest I'd want to see, don't want it too cold.
FlashRS
13
31-08-2015 06:02 PM
mrmann
20-08-2015 11:24 PM
