Turbo Coolant Pipes
Turbo Coolant Pipes
Anyone know the best place to get replacement coolant pipes (the metal ones). Mine have been weeping for a while and the input one has just shit itself tonight.
Mines a 2wd with a 2wd manifold and T34 turbo. Im assuming they will just be standard 2wd ones that I need??
I bought some braided ones from ebay a few months ago. They say direct fit but I had to rotate my comporessor housing round to clear the 2wd manifold shoulder/flange. Very well made I will add, but definitely required some fitment work. At around £35 they are cheaper than decent quality braided hose with suitable fittings. I had previously tried to make my own, however the issue I had was finding banjo bolts the right thickness.
cheeRS
cheeRS
cheeRS
cheeRS
http://cgi.ebay.co.uk/SIERRA-RS-COSW...item23112c33c7
Was looking at them, but wasnt sure about fitment as my T34 runs pretty close to manifolds etc.
Yep they're the ones. And the seller got a proper arse on with me when I mailed him to say they didn't fit straight on. Told me I didn't have the knowledge to fit them or very similar! I'm just finishing off a full rebuild on my 2wd saph and I've done everything myself, plus I trained for Ford at a main dealer so I think I do! lol
I'll try to find a pic of my turbo once I had fitted them and post it up. Basically instead of the oil/collant fittings being at 12, 3, 6 & 9 o'clock so-to-speak I had to rotate the centre housing so now they are closer to 10, 1, 4 & 7 o'clock. If I remember correctly I had to bolt on the head side before fitting to the manifold and the oil return underneath required modding to stretch across to the new angle.
Well made though, and good quality fittings. Expect some modding to fit though.
cheeRS
cheeRS
I also had to switch the inlet and outlet coolant pipes around. I did ask CR Turbos 1st and they said it didn't make a difference which was inlet and outlet so that was good enough for me. The turbo is a fresh rebuild from them too so it's not like it wasn't put together correctly.
cheeRS
I bet the leak was around the join between the pipe and ring the banjo goes through ?
Ford used some cheap nasty rubbish material when they joined these two parts together, it is too brittle and can crack.
The PERMANENT 100% EFFECTIVE cure for about £15 is to have these SILVER SOLDERED, it is called silver soldering but is actually brazing but with silver, you will not in a million years break these once joined, so find a local engineering firm that do silver soldering, or even better a retired guy that makes model steam engine/trains as this is fave way on these joining pressured fittings/pipes together, I used my ex's grandad, he makes 1 off steam trains, some taking 3-4 years, every single part hand made.
Turbocharging Technician
Im popping into Pirtek tomorrow and see if they can make me some up with heat resistant flexible pipe with the banjos on the end.
If that fails, I will try getting them soldered.
If not, my mate runs a Engineering company and he said he could get one of his lads to remove all the old stuff and Tig weld them up. Will probably go the free route and have them welded. Just got some new banjo bolts and washers too. Feckin cossies. The cars gonna be vertually new by the time its finished with me
I tried Pirtek myself, and they could supply hosing no problem. However the only banjo bolts they had were too big. I still have them sitting spare as they dont do refunds. £12 odd as well, just for the banjo - the bolt was arounf £9 extra!!! Only thing they offered was to shave the head of the bolt down for me but that didn't work either as it was still too wide with the banjo to fit between the manifold and turbo housing.
cheeRS
cheeRS
cheeRS
cheeRS
I can get all the banjo sizes, most around £3-£4, DON'T TIG weld it, it's too brittle, braizing with std braizing rods would be MUCH better than TIG, but if you want it silver soldered which is easily the best way to go, send them to me, but around 1 week turn around as have to drop off and collect from a mate 25 miles away, if I'm lucky and he's not busy will do there and then.
andy130
02-10-2015 08:48 PM
Matt Baxter
16-09-2015 08:30 PM
AndrewStrang
01-09-2015 11:16 AM
