Fuel Pump Rewire
Fuel Pump Rewire
Thought my pump had seized so took the opportunity to buy a 044 pump and MSD loom. Fitted today with new loom and old pump + used for trigger on new loom. When i turn ignition on, I get 1 second apporx of pump prime and then nothing. Put a volt meter on it and getting 8v for a second then 0v.
I assumed the new loom with its own relay would do away with the old relay, but im thinking the problem must be with the old relay as its still been used to trigger the new one?
Is the OE pump relay the purple one under passenger dash and 30amp fuse?
Any advice??
Any advice??
No the existing pump wiring becomes the switch feed for your new loom so if you take the old relay out you'll have no feed to the old wiring. Have you tried starting it as the pump will only prime to pressurise the system
Does anyone know which relay is for the fuel pump on a 2wd saff??
The standard relay is yellow, it is only supposted to prime for a short while, it's is only when the engine is running does the pump run continiously.
Clearly you are getting power there albeit a bit low perhaps, so the relay is ok in theory, have you checked the earth?
If it were me personally I would only want one relay so akin to the original setup, I really can't the point in having 2 relays.
Martin
Martin
Martin
Martin
The new loom is earthed from the battery. I found the OE relay, and its only got a 20amp fuse in it, its not popped but thought it was supposed to be 30amp.
Im nipping over to see Gordon Scott this weekend to try a different relay.
As martysmartie said have you checked the earths , if your getting 8V you know its working albeit a bit low . The information you have put is a bit lacking in terms of fuel pressure etc , have you tried to start the car at all? The prime will only be a short period and yes the O.E fuel relay feeds the amal valve and idle valve aswell as the pump. It should work fine using the oe setup to trigger your new relay. If not then check it all and the earths .
I was going to try a completely seperate fuel loom. Using the o.e ecu relay(l6) to feed iscv and amal instead of the o.e fuel relay . Does anyone know if thats ok ? sorry to hijack the thread but it just seems worth asking as OP may want the same, iirc i,ve seen it mentioned before on here but cant find thread
Look it's NOT rocket science, a 1 second prime is unlikely to be of any use to anyone, if that's the duration, especially after being left overnight, there is a valve in the pump to stop drain back, but they seriously are not that good, and won't hold pressure overnight, not even a brand new one.
The old relay cannot alter the prime duration, but can be easily(and safely) taken out by putting a wire across terminal 30(battery) and 87(output), the output from the fuel pump relay also feeds the amal valve, so unless you do a bit of rewiring you need a jumper across 30 + 87, but as the load if massively reduced only a thin wire is needed to run the amal valve, there's no point though unless it is causing a problem.
Gonna have to get a sparky to have a look as my understanding of auto electrics is limited
Is there any reason why the new relay would trigger the pump with no ignition on. If I touch the + wires at the battery and only the - wire from the new loom, the pump starts. If i conenct the negative leads from the car first and then the negative lead from the new loom it doesnt.
Anyway, now the system is pressurised it starts on the key and runs, but I suspect its because there pressure there and it will just cut out after a while. Its tight in the garage at the minute, will have to try again tomorrow.
Does it cut out or do you think it will??? If it starts and idles check if the pump is running with it idleing. If your getting your prime signal then once its started it runs its doing what it is sposed to do.
Or are you just not happy with the voltage?
Got my head battered. If I pull the fuse on the MSD loom (so it doesnt fire the pump), connect all the + connections at the battery, but only the negative from the MSD loom, the new relay clicks open and closed (without the old relay connected, so its empty), and no ignition.
So it must be getting voltage on the old pin 86 which is the old pump + on the new loom. Either that or the new relays wired wrong??
Ive come to the conclusion the cars just gonna do what the feck it likes. Put it all together again and now it runs. 13.2v at the pump constant. Been out all day, and it runs fine
The strange thing is, when ignition is turned on, it runs the pump constantly no priming etc just runs. If i leave the ignition on without starting the engine, the pump just runs and runs and runs.....
After 2 seconds or so, you can hear the MSD relay click, but pump still runs. Im wondering if its something to do with the Imobiliser.
Im gonna ask my mate to have a look, as the OE relay and the new MSD loom obviously arent working together as they should. Ive not wired anything up other than the trigger from the old pump + as per the instructions with the loom.
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
