Oil flow
Oil flow
Hi dose the oil flow from the middle of the filter housing and back in round the out side or the other way round
fitting the remote oil filter housing and cooler
Other way around, where the filter goes on the block you will see a hole at the bottom of the area inside the "ring" the filter seals on, this is DIRECTLY from the oil pump, so it flows through the outer holes into/through the filter and out the single one in the centre into the oil gallery, and onto crank/pistons etc etc.
