Just my opinion, but the std cam causes valve/piston contact, so no way will you get away without pocketing the pistons on a BD16 cam.
I if doing it myself would likely use a decent set of new single springs, but would seek advice from the cam maker.
I've heard that you need to modify the head when fitting a 16 not for the springs for the actual cam as someone had fitted one and it failed within 10 miles
i am using a bd16 in my escort ,your pistons will need pocketing as well as use double valve springs i also had my valve spring seats machined so the springs do not become coil bound .
Yes James,you sell the Newmans springs which fit a standard head as you say,had to have my head machined to take the Iskys,wasn't a problem as the head was off for porting etc at the time.
James,going back to Brammers BD16 inlet cam,he will have to have cut outs in the pistons yes as I understand the case to be?Where as with an AB07 Ahmed inlet cam it is designed for engines without valve cut outs.
I am considering an AB07 exhaust cam for my car shortly.
After speaking to James i have completely had to re think the engine spec due to the levels at what the turbo will be working at so now i am looking at a BD16 and BD8 combination along with a long studded 200 bottom end with pocketed pistons - it will just take longer to do but.....
As i'm using a GT3076 i'm almost convinced that at higher revs the valves and pistons may touch.
If you are using a big turbocharger you will need to rev it to get the full potential so double springs are a very good idea
If you run the BD16 or BD16+ inlet with double springs is it fine to run the exhaust side with standard springs.
Also is the only difference between Newman springs and ISKY the diameter of the spring? i take it for ISKY you remove the standard valve spring seat and machine a seat within the head?
Yes Chris,u only need the inlet side if running a standard ex cam as far as I am aware,confirm with james though for sure.,mine has both though as I have the bd14 ex cam at the moment which is being replaced soon.
Double springs are advised when you want to start running to 8000rpm + regardless of the cam profile as you now have less time to shut the valve on every stroke.
