Exhaust manifold swap
Need some advice on fitting a 2 wd manifold on to my 3 door, it came with a 4x4 manifold fitted with a t34 turbo and I've been offered a good uncracked 2wd manifold very cheap, I gather I'll have to spin the compressor housing round a bit so the boost pipe will fit on the turbo out let but was wandering if I'll need a new exhaust or will my existing system will still fit , any advise is greatly appreciated cheers
It would seem it varies, mostly depending on which exhaust system you have, some a bit short, so a bit long in the downpipe, so a bit hit and miss, personally unless you want loads of power I'd have kept the 4wd manifold.
Fair enough, it's just a stage 3 set up not sure on power but must be round the 330 ish mark, will probably just keep the 4x4 one on now if it makes no difference, cheers guys
caprixpack
25-09-2015 07:53 PM
