Best way to leak test intercooler and hose s
Any ideas on The best way to do this , was thinking of fitting an old bit of innertube with a valve on and fastening with a jubblee clip to the front end of the turbo as a way to get the air in , Not sure if this is the best way or not?
cheers
cheers
That sounds perfect. Maybe use a motorbike tube as it'll be more rigid. Decent bike pump will have a pressure guage too so you can pump up to certain pressure and listen for leaks.
Charlie
Charlie
Another way is to use a rubber block(cylindrical) about 2mm smaller than the inner bore, then drill through the centre, put a large(almost same size as rubber) metal plate either side, bolt through the lot, when tightened if using a soft rubber it will expand outwards sealing the end.
The end with the gauge simply use a bolt of the fine pitch as used in a std valve, drill hole down centre of bolt, this can be clamped like normal but lets you put air in at the same time.
Russ Payne
25-09-2015 08:29 PM
