Cossie boost 'cough'
Hi guy having a few issues with the saph, started off with complete loss of power over 7 psi boost, had new phase sensor and cps fitted (gapped) and plugs hard wired on bulkhead, all plus on engine were contact cleaned and earths cleaned up.
Misfire then got better would get to 10psi also noticed exhaust manifold and downpipe glowing red after nursing it home off boost stuck it back in the garage in a strop!
Now fitted a new 044 pump with decent loom and relay etc, and made and fitted a junction box on batt (now round post) also have fitted a new act sensor.
Still not sorted have full boost back 17 peak 15 held but get an occasional cough from it, hard to explain but a slight miss not a full blown one.
It has had most sensors replaced new fuel etc.
Is there anything obvious I have missed oh plugs rotor arm and cap have all been cleaned as well.
A common connector to give trouble is the female(have to be wouldn't it!!) side of the CPS, ie the loom plug, over the years the terminals lose their tension on the male pins of the sensor plug, worth a check and see if there is any dizzy side to side movement.
Forgot to say that the dizzy bearings are fine checked all that out when phase sensor was fitted. Will check cps connector over the weekend at somepoint.
Thanks
Thanks
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
