PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 20-03-2010, 03:34 PM   #1
Brettski mk2
Trader Score: (3)
Brettski mk2 is on a distinguished road
Default bit of help needed
Hi all I have fitted the grp A chassis engine mounts and in doing so have made a new problem.the new engine mounts foul the bit where the oil filter is screwed on to "the alloy part" So I will use a remote oil filter housing and move it on to the inner wing
Can I get rid of the stainless steel oil cooler/oil warmer thing with the two coolant hoses on one goes to the head and one to the heaters,I am not using a heater in the car as its a race car
What can I do with the hose that comes out of the head?blank it off or pipe it somewhere else?
cheers
Brettski mk2 is offline   Reply With Quote
Old 20-03-2010, 04:09 PM   #2
MannheimAlex
MannheimAlex's Avatar
Trader Score: (0)
MannheimAlex is on a distinguished road
As far as i know, the second heater pipe goes into the thermostat housing. So if you remove the oil cooler and the heather, then connect the pipe from the head to the thermostat housing.
MannheimAlex is online now   Reply With Quote
Old 21-03-2010, 10:36 AM   #3
Brettski mk2
Trader Score: (3)
Quote:
Cheers sounds so easy now
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
