| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
#2 |
![]() BANNED |
What off set wheels are they ?, what size are they ?, the 3 door hub is different in many ways, most noticeably cost, you won't get any change out of £150 a pair s/h, then you also may have to buy new tca's, as the outer joints are different and won't fit some std hubs.
I can only assume you are using a larger wheel diametre, and it is hitting the spring pan ?, the spring pan on the cossie is much higher, ie further away from the tyre, on a cossie with std wheels/tyres, you can't squeeze your little finger in the gap between the tyre and spring pan, there is a gap but very small. tabetha |
#3 |
they are standard 3 door cosworth wheels 15/205/45, yea its hitting the spring pan, and ive looked at cosworth suspensions and there doesnt look any difference in height, ill get cosworth suspension then and see how it goes if there is a slight gap, thanks for the help
was going to get these, they come up on the cheap now and then http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
__________________
#4 | |
Quote:
#5 |
![]() BANNED |
I had std cossie 2wd suspension on my last sierra, with 3 door hubs, on 205/50X15, and also to start with the std hubs, went on no problem.
As jon has pointed out these hubs on ebay are cossie, but not 3 door, easy way to tell they are cossie is the area at the base of the strut is filled in, whereas it is sculpted out on a non cossie hub. Nothing wrong with std sapphy hubs, a lot cheaper than 3 door hubs, and foir what you're wanting just as good, just make sure they are 2wd hubs, 4wd take different struts(thicker body). tabetha |
#6 |
ok cheers thanks for the help
__________________
| Display Modes | |
