PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 15-03-2010, 12:55 AM   #1
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
COLEYST200 is an unknown quantity at this point
ian cole
Default fueling problem
right iv got a fueling problem on my 3dr cosworth wot its doing is when the car is nise and warm i can set the fueling on the ECU with the help of my stack AFR gauge and set it to about 14.7 / 14.4 and the fuel reg is running at 3bar and 3.5bar with the pipe of . so then i go for a drive and bring it onto boost and bang it back fires like a dog and the AFR gauge is in the RED very very lean i pull up and the AFR setules in the mid 12,s i then pull off and it gose very lean till im just hovering the gas . pull up and the fueling is in the RED again very lean .iv just done a test on the wires running the FPS and the MAP and the wires are all good the car is on its second fuel reg which is holding pressure good as i have a gauge which i can see wot the fuel pressure .
SO WOT DO YOU THINK IT COULD BE THEN
__________________
Birmingham group
Click here to take a look at my three door project.
COLEYST200 is offline   Reply With Quote
Old 15-03-2010, 12:02 PM   #2
Trader Score: (0)
tabetha will become famous soon enough
Stop wasting your time and money, and get it mapped correctly, any faults will also become apparent and be dealt with.
Is your lambda calibrated ?
tabetha is offline   Reply With Quote
Old 15-03-2010, 05:33 PM   #3
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
ian cole
all i no is its a stack one and its plug and play i got it off martin . and also iv now got the ££££ put a side to have it all mapped but i now there is a problem and i just wont to sort it then as soon as its sorted i will ring martin to get it booked in . as if i dont sort it out my self it means im having to pay martin to do it ontop of having it all setup and mapped hope you under stand wot im saying
__________________
Birmingham group
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
