PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 14-03-2010, 06:48 PM   #1
cossie330
cossie330's Avatar
Trader Score: (0)
cossie330 is on a distinguished road
Default Radiator Fans
Hi what aftermarket radiator fans would you go for on a 4x4 saff cossie also what size?
Cheers Jason
cossie330 is online now   Reply With Quote
Old 14-03-2010, 07:14 PM   #2
fezzajsy
Trader Score: (9)
fezzajsy is an unknown quantity at this point
Send a message via MSN to fezzajsy Send a message via Yahoo to fezzajsy
been looking at the pro alloy set up myself..
fezzajsy is offline   Reply With Quote
Old 14-03-2010, 07:15 PM   #3
fezzajsy
Trader Score: (9)
Old 14-03-2010, 07:57 PM   #4
Trader Score: (0)
tabetha will become famous soon enough
My dads used lots of spals on his xr4i, as they kept breaking all the time, unsually between 18-24 months old, even though hardly used, mostly same problem, seizure due to the internal motor magnets falling/coming away from casing inside and jamming, after the 3rd one he went Kenlowe, more money to start with but 4 years on not missed a beat, and has now worked out cheaper than replacing spals over that period.
tabetha is offline   Reply With Quote
Old 14-03-2010, 08:44 PM   #5
fezzajsy
Trader Score: (9)
cheers for the info Tabs
Old 14-03-2010, 08:50 PM   #6
Mike Kerbey
Mike Kerbey's Avatar
Trader Score: (1)
Mike Kerbey is an unknown quantity at this point
I have the pro alloy fan set up on mine and they work well, move plenty off air when they come on. Ive had them for just over a year and havent had any problems with them (yet) lol
Mike Kerbey is offline   Reply With Quote
Old 14-03-2010, 09:47 PM   #7
cossie330
cossie330's Avatar
Trader Score: (0)
Cheers for the replies guys I was thinking Kenlowe but not sure what size to get?
Old 14-03-2010, 10:37 PM   #8
charlie luciano
charlie luciano's Avatar
Trader Score: (3)
charlie luciano is on a distinguished road
Send a message via MSN to charlie luciano
Quote:
What he said have the pro alloy set up on my car, better fans (more blades) than standard, a lot quieter and run less current so your fan wiring loom don't get too hot and melt
Luciano
__________________
Middlesex RSOC's Front Man
www.sccperformance.com
www.madevelopments.com
www.middx-rsoc.co.uk
charlie luciano is offline   Reply With Quote
Old 15-03-2010, 12:10 PM   #9
Trader Score: (0)
Quote:
A large single will be fine, of around 14", remember the only time it will be needed is when there is insufficient natural air flow to cool, so speeds are low, and hence heat isn't massive.
The curved vane Kenlowe one is the kiddie, the std fans are TOTALLY adequate though if working ok, a simple fan rewire is a lot cheaper than new ones, yes the fans do consume more power than newer curved vane sorts, but you won't notice any power difference with the std fans vs newer ones, std fans were just picked out of the ford parts bin, but do the job, I certainly won't be changing, unless they die, then I'd look around the scrappies are curved vane are pretty std these days.
Don't be fooled into buying a cool running stat either it is a gimmick, that offers no protection whatsoever, heat doesn't kill HG boost does, I set my ecu for the fans to come on at 105C and go off at 102C, didn't bother it, I have a 88C stat, and currently set at 95C on 92C off.
Old 15-03-2010, 06:56 PM   #10
cossie330
cossie330's Avatar
Trader Score: (0)
Hi, I have done a fan rewire loom but one of my original fans had seized and caused my original loom to melt so I thought about putting two 11" aftermarket fans on there aswell as my new fan loom i made
Cheers Jason
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
