1000 ccm injectors
Look on ebay.com, they have the holley listed 230409129833, then look around the site, you will find injectors up to 5400CC/min 180lb, they also have the bosch 1600CC injector.
http://cgi.ebay.com/ebaymotors/ws/eB...%3D1&viewitem=
And these are low impedance..
I ran high and low on my ecu with NO resistors, detected zero difference between high and low on the rollers, and also when using the low with resistors, after sustained use the injectors started to overheat, and stick when using low, when it(ecu) is specced for high.
At the end of the day it will need mapping to suit the injectors so any differences will not matter.
Rather odd person he is, what does he think the manufacturer does to suit high or low!!
I trust the person I use, you should do as you want, he doesn't just happen to sell the ones you want does he ?
Personally I don't trust much that comes from the us.
a) Low-“impedance” = low electrical resistance = more energy flowed to open the injector = faster opening speed.
b) The difference in speed used to be huge.
c) Now the fastest high-impedance injectors are faster than the normal low-impedance even though they don’t use as much electrical power to work.
d) Vehicle makers no longer worry about low-impedance because the circuits needed to control the injectors are more expensive. Very little development is being done on low-impedance injectors (except for direct injection which sprays directly into the combustion chamber).
So, that explains why the lows are considered superior to the highs. But, that is a reputation that is getting less true every year, etc. These Genesis 1000cc (and the specific Bosch family that the solenoids came from) are SUPER fast. That’s why they allow for smooth tuning even though they are so big.
Okay, and here is lesson number two:
1) Notice that I said that the low-impedance injectors have faster opening speeds. That’s because they have stronger solenoids. These take that extra electricity to work properly.
2) They also have faster closing speeds because there is a stronger/heavier “return” spring that acts against the solenoid.
3) The return spring does not change in strength because it is purely mechanical.
4) By adding resistors to the low-impedance injector you increase the resistance.
5) At this point you will have converted low-impedance to high-impedance. (Again “impedance” = resistance which blocks electrical energy.)
6) Now, you will have a weakened solenoid but a super-strong return spring.
7) The result is much slower opening time (but no change to the closing time).
In short… adding resistors to low-impedance injectors makes NO SENSE! J You will get much better performance out of a high-impedance injector that has a proper balance between opening and closing strength. I hope all that is easy to understand!
Theory doesn't always work out in practice, a major part you are forgetting is I assume you are not bothered bothered about 1/1000 of a sec saving, and not in the F1 races, lows with resistors are perfectly adequate for road use, a lot of stuff especially from the states is sold on bullshit, like the flywheels lightened to give + 20bhp WTF!!
Remember the purpose of a business is to make money, there 's many many very sicessful cars running what I and millions of others use.
The second a new bit comes out all the tuners rave about it as being the best, does that mean they were selling us shit before ?, no but they're hardly going to say this bit is no better than the bit you already have but please buy it I want your money.
PassionFords Creator
All I will say is those saying they are the same once you apply a resistor have no idea how the two different systems work as they are very different injectors. Just use what your ECU and respective mapper recomend.
Google saturated coil injectors and peak and hold injectors if you want to know more info on the differences.
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
