PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 06-02-2010, 11:30 PM   #1
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
bad boy rs is an unknown quantity at this point
Default strut brace / heat shield
I fitted my group a single bar strut brace today and now my turbo heat shield doesnt fit, what are the options ?
if i heat wrap my exhaust down pipe will it be enough to stop the brake resoviour from melting ?
cheers paul
__________________
395 bhp & 410 lb/ft
bad boy rs is offline   Reply With Quote
Old 06-02-2010, 11:35 PM   #2
English
English's Avatar
Trader Score: (0)
English is on a distinguished road
OR - customise your existing heat shield
If it's a standard one, neatly cut out the section that clashes with the strut brace with a hacksaw. Then you can either leave it like this, put some edging on the edge of the cut out section, or buy some heatsheild material which is usually available in sheets and install a section of that in a shape that conforms to the strut brace, and then rivet it onto the original shield.
Or, even make a whole new shield out of the heat shield material, and use your original sheild as a template.
It'll be like Blue Peter ha ha
English is offline   Reply With Quote
Old 06-02-2010, 11:54 PM   #3
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
i was thinking somethings along them lines, would a 4x4 one fit as my original 2wd one is pretty shagged
__________________
395 bhp & 410 lb/ft
Old 07-02-2010, 01:34 AM   #4
English
English's Avatar
Trader Score: (0)
If you do go the heat wrap way, you'll need to wrap as much as you can.
The piece of the 2WD exhaust manifold that joins to the turbo will definately need wrapping as otherwise you start melting all your cables etc. and you would probably be well served to wrap as much of both parts as you can.
Or there's that ceramic coating...
The heat shield way is good. I have a combination of cut back standard shield and exhaust wrap. Probably still have more heatproofing to do as well.
Old 07-02-2010, 03:00 PM   #5
Trader Score: (0)
tabetha will become famous soon enough
I cut mine out to fit around the strut brace.
tabetha is offline   Reply With Quote
Old 07-02-2010, 03:03 PM   #6
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
Quote:
any pics mate ?
__________________
395 bhp & 410 lb/ft
Old 07-02-2010, 03:42 PM   #7
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Trader Score: (0)
ajamesc is on a distinguished road
i got a new 2wd drive one then choped!
__________________
ajamesc is offline   Reply With Quote
Old 07-02-2010, 07:17 PM   #8
Trader Score: (0)
I don't know how to put piccies up!!
All it is is literally I put the brace on resting on heat shield/the drivers side, but connected loosely on the nearside, then got a hacksaw and did the buisness, no good for bufty boys, I'm into function rather than looks, it looks butchered but it is!!
Old 07-02-2010, 07:27 PM   #9
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
thanks for that i see what you mean now. My original one is abit battered on the inside anyone know where to get some heat reflective stuff ?
What turbo is that andy looks massive
__________________
395 bhp & 410 lb/ft
Old 07-02-2010, 07:38 PM   #10
ajamesc
ajamesc's Avatar
Trader Score: (0)
its a gt30
__________________
Old 07-02-2010, 07:40 PM   #11
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
Quote:
Originally Posted by ajamesc View Post
its a gt30
__________________
395 bhp & 410 lb/ft
Old 07-02-2010, 07:52 PM   #12
RS500/364
Trader Score: (0)
RS500/364 is an unknown quantity at this point
Send a message via MSN to RS500/364 Send a message via Yahoo to RS500/364
My RS500 i just did a hole thought it looks good just to dark to do a pic
__________________
RS500 fully balanced blueprinted bd14 8x 803 racing loom coil pack verns Field Motorsport ***BHP FORGET SECs T4 Air2Air koni Ahmed springs Samco Pectel monitor poly bush WITH SOME EXTRA and I HAVE A SAFF 4x4 :Op more to follow !!
www.grovegarage.com
www.fieldmotorsport.com
www.roosemotorsport.co.uk
www.turbodevelopments.co.uk
www.diamondinsurance.net
http://members.lycos.co.uk/rscosworth/
RS500/364 is online now   Reply With Quote
Old 08-02-2010, 12:43 AM   #13
BIG TONY RS
Black Sapph !
BIG TONY RS's Avatar
Trader Score: (8)
BIG TONY RS is an unknown quantity at this point
Rscosworthtony
Send a message via MSN to BIG TONY RS
Hello mate i had an escos one and it didnt fit after i fitted the bigger turbo so i just made a heatshield got some material and just bend it to fit.
__________________
www.rapidford.co.uk
BIG TONY RS is online now   Reply With Quote
Old 08-02-2010, 03:49 AM   #14
English
English's Avatar
Trader Score: (0)
Look under insualtion/heatproofing in the yellowpages
Should be someone there that sells it - usually aluminium with ceramic coating
So easy to bend and fold to shape. Make a template out of cardboard and then fold it up.
Old 08-02-2010, 07:13 AM   #15
BRAMMER
GT Series baby!!!!!!!
BRAMMER's Avatar
Trader Score: (18)
BRAMMER is an unknown quantity at this point
RS Bram rs_brammer
I used nimbus material from nimbus motorsport, it's the lite version and is a must if you want to make a custom shield and cheap
BRAMMER is online now   Reply With Quote
Old 08-02-2010, 08:18 AM   #16
gibbo frst
Trader Score: (2)
gibbo frst is on a distinguished road
On mine I drilled the bottom mount off and raised it a few inch which lowered the heatshield in the bay under the strut brace and made new bracket for the top. Was a bit closer to the turbo but worked fine
gibbo frst is offline   Reply With Quote
Old 08-02-2010, 04:49 PM   #17
Trader Score: (0)
You could always but a turbo blanket to keep it nice and warm, will stop heat getting away, if used with wrap on downpipe.
Old 08-02-2010, 05:52 PM   #18
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
cheers for the replys, think im going to go with brammers idea, looked on the website and its a good price. Will bend it round the old one i think but a touch smaller so to miss the brace
__________________
395 bhp & 410 lb/ft
Old 08-02-2010, 05:55 PM   #19
Kitchen Devil
Trader Score: (7)
Kitchen Devil is on a distinguished road
Does ceramic coating make that much difference to the heat radiated from the manifold??
I was thinking of getting my manifold done to make it look a bit smarter more than anything (a bit bufty I know but I hate rusty looking manifolds!!) so if it keeps the underbonnet temps down, that's an added bonus!
__________________
500 Bhp and 2WD in the making...
Kitchen Devil is offline   Reply With Quote
Old 08-02-2010, 11:07 PM   #20
RSaustin
Cossie is NO1......
Trader Score: (2)
RSaustin is on a distinguished road
Look in latest copy of retro ford march10 page 91 to 95 a good read on heat wrap and ceramic coating both tested £315 ceramic coating looks the nuts
RSaustin is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
