PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 06-02-2010, 10:37 PM   #1
BRAMMER
GT Series baby!!!!!!!
BRAMMER's Avatar
Trader Score: (18)
BRAMMER is an unknown quantity at this point
RS Bram rs_brammer
Default Starting issues - 03/03
After changing a few things over the winter it's come to that time to start and.... it won't fire correctly and sounds like it's firing on 3
What i have is the car won't start on the key like it used to, you pump the peddle and it starts but when you let of the pedal it dies.
I tried the bulb in the plugs to see if it lights when the power is turned on.
When plugged into the air injector plug it lights but not in iscv, crank sensor, distributor, injectors so thats most of the 2 pin plugs that side of the loom (ryan loom) so this gets me thinking is it electrical or fuel but confused as its actually starting
BRAMMER is online now   Reply With Quote
Old 06-02-2010, 10:59 PM   #2
English
English's Avatar
Trader Score: (0)
English is on a distinguished road
Check all electrical connections. Make sure your multiplugs are all on the correct way etc.
Check all air lines to make sure none are old and perished with tiny holes you may not be able to see, and that they are all secure.
Perhaps the base idle is set too low as a simple check. Undo locknut and wind idle screw out to turn it up. I took my idle screw right out first and cleaned it as the end gets clogged with juicy bits of crap.
If you take the ISCV out and get someone to turn on the ignition, but NOT start it, usually the ISCV plunger will deflect momentarily so that's a simple check for that. Good time to clean and oil it too if you haven't for a while.
Check distributor phase sensor gap .2mm to .3mm between sensor and the lobes of the shaft, and make sure it has good insulation on its leads.
Check crank position sensor gap .6mm I think?
Throttle position sensor could be something to check as well. Apparently it's usually about right when the mounting grooves are centred on the screws, so check if it's visually way out in that respect.
If it starts, it must have fuel. You must be able to hear if the fuel pump is priming when you turn on the ignition?
That's my limited suggestions.
Tell us what things you changed as well as that could help isolate the problem.
Good luck
English is offline   Reply With Quote
Old 06-02-2010, 11:09 PM   #3
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Right i should have stated that all sensor are set right and non have been adjusted as the car was fine before i took the inlet off, everything is absolutely spotless as it's just been painted and put back together
It's the light in the plugs thats confusing me as they should light and they don't.
The pump is priming
Old 06-02-2010, 11:22 PM   #4
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
COLEYST200 is an unknown quantity at this point
ian cole
right have you put a new set of plugs in and you might have to alter the tick over as you now have more air in the plenum all so pull all the plugs out replug them into the HT leads and put them on top of you rocker cover and turn the key and look at all the plugs to see it there all sparking
__________________
Birmingham group
Click here to take a look at my three door project.
COLEYST200 is online now   Reply With Quote
Old 06-02-2010, 11:24 PM   #5
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
ian cole
O and have you got your firing order right as you have had all the leads of and put back onto your coil pack just a fort
__________________
Birmingham group
Old 06-02-2010, 11:26 PM   #6
English
English's Avatar
Trader Score: (0)
Easiest way to check spark is take a plug out and turn over with the plug attached to the lead and the plug thread earthed against the engine - I earthed mine on the turbo damper (I have the same as yours) - you can visually see the spark as you turn it over.
By the way, your engine is a work of art.
Must be so frustrating to have it looking so good and face the prospect of taking it apart again.
If you took the inlet off, there is a possibility of an air leak, but there is also the possibility that you used to have an air leak, and since you did the work, it's sealed up better, so the engine isn't getting enough air anymore.
This theory adds up too in that the engine starts when you open the throttle which lets more air in.
I recently finished a rebuild on my engine. Yesterday, I was trying to sort out erratic idling. When the engine was up to temperature, I removed my ISCV multiplug, the engine would die. I realised for this to happen, the engine wasn't getting enough air with the ISCV closed for the engine to run.
I wound out my idle screw visciously (a few turns at a time) and kept restarting the engine and then pulling the ISCV plug off until it ran with the ISCV disconnected, then set the base idle. This needs to be done with the engine at temperature obvously.
I really don't know enough to be advising you, but you could try it. Perhaps idle CO is an issue?
Old 06-02-2010, 11:27 PM   #7
Moonstone Steve
Trader Score: (1)
Moonstone Steve is on a distinguished road
map sensor plug or piping maybe??
Steve
__________________
www.rapidford.co.uK
Moonstone Steve is online now   Reply With Quote
Old 06-02-2010, 11:54 PM   #8
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Right just been down the idle screw all the way out and it does attempt to start better.
The firing order is easy on wasted spark it's all labelled on the coil pack and correct
I can't take the plugs out as i haven't got a socket here.
I'm still confused as to why the bulb won't light when the power is on at the injectors but it will at the air to air plug
I know all the usual checks with gaps etc but nothing has been touched only the inlet off and everything is cranked down well with cometic gaskets.
The only difference is the spacer plate on the now 4x4 inlet.
But why would the car only fire on 3?
Strange
Old 06-02-2010, 11:56 PM   #9
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
The last time i had starting issues it was the baby board but then i wasn't getting power at the injectors hence no firing at all but after fitting a new board the injector plugs would light up so why is their no light to any of the 2 pin plugs on that side?
Old 07-02-2010, 01:29 AM   #10
English
English's Avatar
Trader Score: (0)
Ok, you have changed to a 4x4 inlet - have you changed the throttle position sensor to a 2WD one?
The 2WD is a PF01 and the 4WD is a PF09
The 2WD is open circuit when throttle fully closed, and then when throttle is moved switch closes and goes from about 5v to near zero volts at throttle wide open.
The 4WD is always closed and goes from near zero volts at throttle closed to nearly 5 volts at throttle wide open.
I heard that you can use a 4WD one on a 2WD but you have to change the polarity of the multiplug. Please check this before doing it.
Your idle screw shouldn't need to be ALL the way out. It's quite a long screw. Mine probably has about 10mm of threaded section out of the throttle body, some of which is covered by the locknut, but obviously yours is a different engine and they will be different.
I'd check the TPS to see what one you have.
Old 07-02-2010, 01:35 AM   #11
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Sorry mate i'll give the you quick spec of the car, L8, T38, Siemens injectors, wasted spark, msd chip, 4x4 inlet the car already has the 4x4 throttle as it was running with it before and was set with a multi metre so is smack on the setting.
It's a wierd one really as the car fires but sounds like on 3, correct firing order and plugs were new before the winter with the top really tight, 909 leads it's something simple i know but i'm racking my head thinking.
Old 07-02-2010, 01:40 AM   #12
English
English's Avatar
Trader Score: (0)
Ha! I know the feeling mate. It'll be some stupid little thing.
It must be late there. Go to bed and you'll wake up in the morning with the answer ha ha
Old 07-02-2010, 10:29 AM   #13
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
bad boy rs is an unknown quantity at this point
any luck mate ? the joys of owning a cossy, this is usualy what happens to me we should just leave them all standard
__________________
395 bhp & 410 lb/ft
bad boy rs is offline   Reply With Quote
Old 07-02-2010, 11:43 AM   #14
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
ian cole
Get the plugs out . Or get some one to turn the key and get it firing and pull the HT leads off one at a time and put them back on and listen to the motor and if its a plug that is down you will here no chang when you pull one of them off
__________________
Birmingham group
Old 07-02-2010, 11:48 AM   #15
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
ian cole
all so have you repluged in the dizzy as i forgot to do this on my car when i put the wast spark on my car it would coth but would not start i think as you said its going to be somthing that you will kick your self for
__________________
Birmingham group
Old 07-02-2010, 01:43 PM   #16
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
The car ticks over but sounds like on 2 or 3 with the idle screw turned nearly all the way out??
On my way out to get a spark plug socket so we'll see what happens with that.
All the plugs are in mate and double checked
Old 07-02-2010, 01:51 PM   #17
AndyPen
AndyPen's Avatar
Trader Score: (22)
AndyPen is an unknown quantity at this point
Pop the leads off one by one mate - spot the bad ones. Might even be wet with fuel in there if they ain't firing???
__________________
AndyPen is offline   Reply With Quote
Old 07-02-2010, 02:20 PM   #18
gingerturbo
gingerturbo's Avatar
Trader Score: (1)
gingerturbo is an unknown quantity at this point
best way to check is while its ticking over, take of 1 lead at a time to see what ones make a difference, and what leads are ya running, and also have ya checked inside the dizzy
__________________
why live life on the edge....
when you can drive of it sideways...
mmeeeoooww......8 lives left
gingerturbo is offline   Reply With Quote
Old 07-02-2010, 02:20 PM   #19
cosy trav
Trader Score: (1)
cosy trav is an unknown quantity at this point
Chris id check the plugs . Everytime i mess with mine it always fires on 3 cylinders when i go to start it , clean cylinder 3 plug and it works fine after that . Strange its always the same one but im not bothered as it runs fine after it been cleaned .
__________________
3 DR Restoration Updated 16/5/09 . http://bbs.rsownersclub.co.uk/showthread.php?t=147865
cosy trav is offline   Reply With Quote
Old 07-02-2010, 02:41 PM   #20
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Quote:
Quote:
I'll go and check lads and report back
Quote:
It doesn't operate off the dizzy cap as it's got a coil pack
Old 07-02-2010, 02:50 PM   #21
james kiely
Trader Score: (3)
james kiely is on a distinguished road
are you running a cam trigger or a phase sensor brammer,could be the phase sensor ?
cheers james
__________________
cheers james
james kiely is offline   Reply With Quote
Old 07-02-2010, 03:05 PM   #22
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
flat battery now, on charge will try after
I can't see it being a sensor failure as all have been changed and only done 700 miles in 2009
Old 07-02-2010, 04:34 PM   #23
cosy trav
Trader Score: (1)
Thumbs up
You have a PM
__________________
Old 07-02-2010, 07:33 PM   #24
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
ian cole
all so if you have been turning it over a lot you will of fluded the plugs and you will need a new set in there or get them out and put a blow lamp them to durn the fuel out of they they will look ok but trust us all they will have it deep in side and that will make them play up
__________________
Birmingham group
Old 09-02-2010, 05:32 AM   #25
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Right here goes:
checked and all 4 plugs are sparking when taken out of the engine
all 4 leads are in the correct position on both engine and coil pack
all injectors are fitted right in the inlet and rail
I have fuel in the inlet pipe going to the rail
I still DON'T have a light at the injector plugs which is making me think that i have issues with a signal to the injectors, I'll have to speak to MSD about this as i could well have an issue with the new chip or my board again.
Old 09-02-2010, 09:25 PM   #26
cossie4i_
TT T38 Power
Trader Score: (11)
cossie4i_ is an unknown quantity at this point
Send a message via MSN to cossie4i_
Any luck today ?
Steve
__________________
TT T38, AB07 Cam, Ported Head, Hart Inlet, Spec-R intercooler, Air Injectors, Gripper Diff , Turbosystems Mapped.
cossie4i_ is offline   Reply With Quote
Old 10-02-2010, 12:26 AM   #27
cosy trav
Trader Score: (1)
Have you got a 12v feed to one side of the injectors , there negative switched by the ECU if iirc .
That way you should be able to tell if its the feed side or switch side thats the problem .
Could still call over if your stuck and try my L8 Ecu .
__________________
Old 10-02-2010, 07:13 AM   #28
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
ECU should be landing with James today so maybe i'll here something but if all looks find in the ECU i guess it's a waiting game for a L8 W/S car going in.
Trav many thanks for the offer, do you run W/S??
Old 10-02-2010, 04:53 PM   #29
cosy trav
Trader Score: (1)
Never noticed you had wasted spark , im on a dizzy still so trying my ECU wont work after all .. Hope you get it sorted soon . Nowt worse than a problem you cant find .
__________________
Old 19-02-2010, 03:19 PM   #30
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Question that was put to me - doe the coil pack need to be earthed out? as mine is bolted to the strut which has since been powdercoated.
I thought this the other week but then thought well most fit theirs behind the headlights and bolt them down so the actual plastic part of the coil is touching the metal.
If anyone can elaborate
Old 03-03-2010, 09:02 PM   #31
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Right back again with the same issue.
The ECU has been tested and is working fine.
I have checked all the timing marks again to make sure.
All four plugs spark
Fuel feed through the rail
Pump is priming fine
Right and here are the symptoms:-
It seems to fire when i have an earth wire from the coil to battery, the car fires when you put pressure on the pedal and fires (sounds like on 3 cylinders).
The smell of fuel is very strong and is throwing black smoke out of the tail pipe, it's puffing smoke rings out of the exhaust.
When removing the brand new plugs No 1 & 4 are black and No 2 & 3 are clear but wet.
I know it's difficult to diagnose issues without seeing a car but i'm out of ideas without replacing parts at cost.
Can anyone allaberate on the 2 black and 2 clear wet plugs
Old 03-03-2010, 09:19 PM   #32
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
wish i could help mate but havnt a clue, have you spoke to stu since youve had the ecu back ?
__________________
395 bhp & 410 lb/ft
Old 03-03-2010, 09:24 PM   #33
T4matt
Big or small fxck em all
T4matt's Avatar
Trader Score: (0)
T4matt is an unknown quantity at this point
Chris it sounds like its overfueling, have you tried starting it with the idle speed control valve unplugged??? i had this prob with mine
__________________
T4matt is offline   Reply With Quote
Old 03-03-2010, 09:26 PM   #34
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Hows it going Matt, tried that mate makes no difference -
Hows your coming along, will it be done for the shows or you waiting until next year??
Old 03-03-2010, 09:31 PM   #35
james kiely
Trader Score: (3)
could one of your coil packs be gone down chris?
__________________
cheers james
Old 03-03-2010, 09:37 PM   #36
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
Quote:
Its only one complete pack, unsure as i get a spark when testing on the plug so it's indicating a supply. I'm not clued up on the functions of a Standard ford coil pack but could say one side go down as the findings above are separated into 2 sides of the pack 1&4 and 2&3 - i may try and source a spare pack and test.
Old 03-03-2010, 09:42 PM   #37
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
good shout, wasted spark has firing pairs, the centre pin is positive and either side is a swithced earth, one side could have broken down
__________________
395 bhp & 410 lb/ft
Old 03-03-2010, 09:47 PM   #38
bad boy rs
bad boy rs's Avatar
Trader Score: (7)
ignition amp ? if one goes down only 2 cylinders will fire, check middle pin of coil pack for live.then check for swithced earths on outer pins. If all 3 ok coil packs fucked
__________________
395 bhp & 410 lb/ft
Old 03-03-2010, 10:00 PM   #39
BRAMMER
BRAMMER's Avatar
Trader Score: (18)
RS Bram rs_brammer
I'll try a new pack tomorrow see if there's any change
Old 03-03-2010, 10:17 PM   #40
Danny @ Enhanced Performance
Trader Score: (3)
Danny @ Enhanced Performance is on a distinguished road
id say its the blue water temp sender on the back of the head..
i assume youve had the loom unplugged???
if its not the sensor it will be the plug on the loom..
un plug it and check the pins inside..
check plug clean plugs again and try,if that dosnt work change the sensor
cheers danny
Danny @ Enhanced Performance is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
