PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 03-02-2010, 07:38 PM   #1
taittsierra
Trader Score: (0)
taittsierra is on a distinguished road
Default dump valve
hey got me sierra tdi up an running now after a long time
but can anybody help me in how a dump valve goes on a tdi cus i can not find how they go on
i no how to put it on a petrol but need help with the diesel.plz help thanks
taittsierra is offline   Reply With Quote
Old 04-02-2010, 07:50 AM   #2
oldford
Trader Score: (0)
oldford is an unknown quantity at this point
Dump valves do not work on diesels, because there's no throttle and therefor no vacuüm.
Your money is better spend when you donate it to the International Red Cross.
oldford is offline   Reply With Quote
Old 04-02-2010, 08:13 AM   #3
WongRS
Trader Score: (11)
WongRS is an unknown quantity at this point
danwong83
Send a message via MSN to WongRS Send a message via Yahoo to WongRS
you not to run a switch system, basically a microswitch that clicks on when you close the throttle, then then goes to a little control box, which has a feed from the vacume pump for the brakes, then a pipe to the DV, i have never done one on a sierra though.
Quick google search should give you some answer mate.
__________________
Dan.
M.A.Developments 500 spec engine, GT30, Autronic, 1000cc injectors, ST Inlet ETC.....
WongRS is offline   Reply With Quote
Old 07-02-2010, 12:16 AM   #4
21-AARON-21
Trader Score: (0)
21-AARON-21 is on a distinguished road
Yea as above. I went to a scrappy and found a vacuum control solenoid from a fiesta. To fit connect the vacuum solenoid valve with a good t-piece in the brake vacuum line. (make sure the T-piece is secure as when you really need those brakes you may find theyl not be very usefull if the vacuum line has disconnected or is leaking!) Run a vacuum line from the vacuum solenoid valve to the dumpvalve.
The microswitch will need to be placed where it will be triggered when throttle is released. Youl prob need to make a bracket. Use a inline fuse obviously and you have the option of putting a switch in there to stop it working when you dont want it. This allows the dump valve to get the vacuum signal needed to open the dumpvalve. Its pretty pointless on a diesel but i do love the noise
__________________
Fiesta MK3 1.8 TDI conversion!
21-AARON-21 is offline   Reply With Quote
Old 07-02-2010, 12:18 AM   #5
botters
competant bodger
botters's Avatar
Trader Score: (0)
botters will become famous soon enough
my mate had one on his golf gttdi sounded more like a wet fart than a dump valve!
botters is offline   Reply With Quote
Old 07-02-2010, 12:19 AM   #6
m4tt274
m4tt274's Avatar
Trader Score: (2)
m4tt274 is on a distinguished road
Send a message via MSN to m4tt274 Send a message via Yahoo to m4tt274
__________________
mk1 fiesta restoration! - http://passionford.com/forum/restora...-now-on-d.html
m4tt274 is offline   Reply With Quote
Old 07-02-2010, 10:21 AM   #7
WongRS
Trader Score: (11)
danwong83
That was mine with one on, 1.15 on you can hear it best, wasn't letting it dump before then really.
__________________
Dan.
Old 07-02-2010, 12:29 PM   #8
m4tt274
m4tt274's Avatar
Trader Score: (2)
^ that 205 is mad. and smokey
__________________
Old 07-02-2010, 12:38 PM   #9
WongRS
Trader Score: (11)
danwong83
yep! you know what they say, more smoke, more poke?!
The cold start smoke was just due to no cold start on the fuel pump!
__________________
Dan.
Old 07-02-2010, 12:46 PM   #10
m4tt274
m4tt274's Avatar
Trader Score: (2)
yeah, i actually quite fancy a big power diesel, i like the noise they make. was looking at the Vrs skodas after they have been 'altered' there very nice.
so how much power was your 205?
__________________
Old 07-02-2010, 12:57 PM   #11
WongRS
Trader Score: (11)
danwong83
i dont actually know, it made 105 or something like that when it was running really crap (14psi, but fuelling for 24psi), never RR'd it at 24 psi, at a guess 120-130bhp.
Was standard 106 gti sort of speed really, would destroy a VTR.
And would pull itself up a cliff in 5th gear near enough.
__________________
Dan.
Old 07-02-2010, 07:46 PM   #12
21-AARON-21
Trader Score: (0)
Thats the power i hope to be running on my 1.8 TD fiesta conversion after ive sorted the head gasket issues! ive a big FMIC on it and plan to get the fuelling and boost upped from 14psi and rolling roaded to see what is making but id hope about 120 - 130bhp. a big improvement on the standard 59 bhp it had with the 1.8D engine
__________________
Old 08-02-2010, 11:37 PM   #13
taittsierra
Trader Score: (0)
same as that hy i just love the noise of it.did u use a petrol dumpvalve or a diesel one.wer did u get the switch?thanks for reply.
Old 08-02-2010, 11:56 PM   #14
21-AARON-21
Trader Score: (0)
I bought a cheap one of ebay for 50 but got the t piece n all with it, prob a petrol one. I havnt got mine working yet as i currently have the head of mine after a fecked head gasket and broken camshaft i got simple lever microswitch from maplins for a few quid.
I plan to see what what the noise is like from it then maybe pick up a baileys or better quality dump valve off ebay.
__________________
Old 09-02-2010, 12:01 AM   #15
taittsierra
Trader Score: (0)
yea a m8 of mine has a glanza an he has dump valves an t pices laying all over the show so i think il go down a take his hks one.that vacuum control solenoid wer abouts is it on the cars would an escort an a mondy have one's to?
Old 09-02-2010, 12:21 AM   #16
21-AARON-21
Trader Score: (0)
Thatl HKS wil do nicely lol I think so. i pulled vac hoses of a mondy one time in a scrappy and i think there was one up in the top right behind the passenger front strut. Easy way to find would be to find vacuum hoses and trace those around the engine bay till u hit one. Just looks like a small cylinder and will have 2 wires going to it probs.
__________________
Old 09-02-2010, 12:25 AM   #17
taittsierra
Trader Score: (0)
alrite nice wan.il go looking tomoro for it.
wat intercoller are u using for the fiesta cus i have a top mount from a mondy laying in me house but i want a front mount u think der would be much of a power gain between the top one an the front?
Old 09-02-2010, 12:53 AM   #18
21-AARON-21
Trader Score: (0)
The biggest one that would fit of course! lol I got mine and harpipe kit and any extra hoses needed for about 180 total of ebay. I cant compare the front mount im running to the top mount setup ur talking about as i didnt try it on my car first. Youl def get more bhp form the front mount and it will give the car a lot more potential should you later decide to get the fuelling and boost upped!
My car as a 1.8D was only 59bhp, with the top mount 1.8TD it would only be 79bhp. My car feels a lot lot faster than that tho id say its closer to the 90's now with the front mount and standard fuelling and boost. When i get those upped i could be looking at 120-130bhp
__________________
Old 09-02-2010, 12:56 AM   #19
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
COLEYST200 is an unknown quantity at this point
ian cole
Quote:
FPMSL
__________________
Birmingham group
Click here to take a look at my three door project.
COLEYST200 is offline   Reply With Quote
Old 09-02-2010, 01:04 AM   #20
taittsierra
Trader Score: (0)
well in me sierra im running a 2000 1.8td mondeo engine with no intercooler at the min.so im not sure wat bhp it has but i have an autodata program ere dat tells me dat it should have 90bhp with std fuel an boost with the top mount.
so im getting now a saab 9000 intercooler an advancing the timing on the pump cus i heard it works better than just screwing dem out an going to turn up the boost with a maual valve.
wat u think of dat set up?
Old 09-02-2010, 01:13 AM   #21
21-AARON-21
Trader Score: (0)
oh the saab intercoolers good n big Should fit well infront of the radiator too. Ive got a manual controller for mine too, im not sure how to advance the fuel timing, do you actually take the belt off and adjust by a notch or 2 on the belt or is it a smaller tweak and do you loosen the bolts on the fuel pump pulley and do it that way? I was planning on taking mine sumwhere to get it tuned and rolling roaded to see what bhp its sitting at.
__________________
Old 09-02-2010, 01:25 AM   #22
taittsierra
Trader Score: (0)
yea bigger is better.lol.going to get it of ebay.i think it the 3 bolts on the pump u losen dem an rotate it 10 degrees not sure wat way yet still trying to find dat out.dont no if il take it to the rolling road or not cus der not any of dem to close to me but as long as i can race a dturbo or a 90 bhp golf il be happy.
Old 09-02-2010, 01:57 AM   #23
21-AARON-21
Trader Score: (0)
Oh rite il look in2 that. speaking of golfs...I dicked a golf the other nite in mine. He was accelerating flat out trying to pass me from about 50mph. It had just split in2 2 lanes btw not a side by side race down a single carriageway before u think im nuts! You could see him thrusting himself forward in the driver seat like a retard trying 2 go faster! lol he wasnt happy when i put the boot down n pulled away from him easyy!made my day
__________________
Old 09-02-2010, 02:09 AM   #24
taittsierra
Trader Score: (0)
not many carrage ways about me so we are all a bt nuts.lolna i really want mine to sit at about 110bhp but dont no if il get it out of the mondy engine.
il try an find out about the pump an den il put it up on ere sure.
wat car u take ur td lump out of?
Old 09-02-2010, 02:21 AM   #25
21-AARON-21
Trader Score: (0)
cheers mate. im sure ul get 110bhp easy enough mate with the fuel pump advance n upping the boost. I cant be sure exactly, it was a mondy tho and it says 1.8 diesel on the rocker so its an early one probably around 1996. I found it on gumtree and did see it first but not running i just took his word and ended up with head gasket issues lol but i did get it for 130 so what do you expect lol all in all pretty happy with it, just a bit more work than expected having to take the head off lol Back on the road soon tho
whats ur top speed? not that i would ever go over 70... cough cough. mine tops out at 96 im wondering is it the mk3 fiesta non turbo gearbox limiting it just?
__________________
Old 09-02-2010, 12:33 PM   #26
taittsierra
Trader Score: (0)
na that sounds about rite i get about the 100.but i have a sierra gearbox so dont no the diffrence
Old 09-02-2010, 04:12 PM   #27
m4tt274
m4tt274's Avatar
Trader Score: (2)
u have low top speeds because you are proably runnin std sierra ratios but are only revving to 4000rpm and u run off the power band.
but seriously, just buy a pinto or a twin cam and bolt that in.
__________________
Old 09-02-2010, 09:02 PM   #28
21-AARON-21
Trader Score: (0)
not that id have much excuse to go to that speed too often... but nice to know its there if i want it lol
Ive a mk3 fiesta not sierra would n rs turbo gearbox be any better for top speed in that case or will there be no differnce as its caused by the low rpm a diesel has?
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
