problem with iddle
Old 16-01-2010, 08:10 PM
sundera86
sundera86's Avatar
Default problem with iddle
when i try to abjust rpm below 1300 at iddle from basic iddle screw the engine start to vibrate and dont work good. On cold engite it has vibration and very strong air leak from exaust smelling gasoline. Where is my problem
spark plugs or cables or another thing. I was with pts stage 3 chip and there is no this problem, but now i replace it with msd stage 3 non closed loop and the problem starts ? but yesterday i return the pts stage 3 and engine work at the same bad way as with msd stage 3 chip ?
Old 16-01-2010, 09:57 PM
LHD220Turbo
LHD220Turbo's Avatar
its cleary not the chip if its the same problem with the pts chip.
i would check your system for air leaks; is the screw in on the throttle body OK?
Old 16-01-2010, 10:25 PM
martysmartie
martysmartie's Avatar
The air leak can cause this problem if on the exhaust side.
Martin
Old 16-01-2010, 10:57 PM
sundera86
sundera86's Avatar
yes when i try to abjust the screw in throlttle body and put down rpm below 1300 to 1000 - 1100 rpm the engine start to vibrate very
Old 16-01-2010, 10:58 PM
sundera86
sundera86's Avatar
Martin
air leak on the exaust before the turbo or after the turbo
Old 17-01-2010, 06:00 AM
English
English's Avatar
I'm assuming you are turning the idle screw with the ISCV (Idle Speed Control Valve) disconnected.
Old 17-01-2010, 09:22 AM
sundera86
sundera86's Avatar
i abjust iddle screw with disconnected ISCV but anything below 1300 rpm start very strong engine vibrations
Old 18-01-2010, 06:21 AM
English
English's Avatar
I also assume you're doing it when the engine is up to temperature and not on cold start.
Take out the ISCV and thoroughly spray it with electrical contact cleaner. Push the plunger in and out a few times and clean it all out. Also, check the throttle body airways that the ISCV feeds air to and make sure they are clear.
That's the extent of my knowledge. Aside from that, others may be able to suggest things like throttle position sensor may need adjusting etc?
Maybe try checking your ECU for fault codes.
Hope this helps!
Old 18-01-2010, 08:22 AM
sundera86
sundera86's Avatar
how can i clear fault codes on ecu
Old 19-01-2010, 08:17 AM
English
English's Avatar
It's not clearing the codes. You can read if there are any faults with sensors on your car. The ECU has a self check mode.
You can make a small rig up to read the codes for a few pennys. Go to www.bigturbo.co.uk and it tells you under 'fault codes' how to check and read them.
Then, if you have any faults, you can fix them from there.
Old 22-01-2010, 04:12 PM
sundera86
sundera86's Avatar
Hope this helps!
i reapleced throttle position sensor before one year? i dont know what is specific with it abjustment
DAZZER
30-09-2015 08:43 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
Quick Reply: problem with iddle
