PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 21-11-2009, 05:21 PM   #1
Barry R
Barry R's Avatar
Trader Score: (3)
Barry R is an unknown quantity at this point
Default really stiff steering
the steering on the 3 door is stupidly stiff the belts fine the fluid is cool and its defo pumpin so any ideas as what can be wrong
__________________
Barry R is offline   Reply With Quote
Old 21-11-2009, 06:00 PM   #2
Matt Baxter
Back in black!
Trader Score: (33)
Matt Baxter is an unknown quantity at this point
check the uj on the lower column
__________________
My rebuild thread (2wd = proper cossy!)
http://passionford.com/forum/restora...iny-stuff.html
Matt Baxter is offline   Reply With Quote
Old 21-11-2009, 07:06 PM   #3
t4 and greys
cosworth gimp
Trader Score: (5)
t4 and greys is on a distinguished road
few things to check mate as said uj ,also check the steering column bush and also the ignition switch too .... also maybe a bent rack
maybe also worth checking the pumps efficiency too!!! may only be pumping at low pressure
t4 and greys is offline   Reply With Quote
Old 21-11-2009, 07:10 PM   #4
Trader Score: (0)
tabetha will become famous soon enough
Won't be bushes, my bet is bent rack, or needing serious overhaul, ie piston seal leaking.
tabetha is offline   Reply With Quote
Old 21-11-2009, 10:17 PM   #5
Barry R
Barry R's Avatar
Trader Score: (3)
It was fine before i parked it up its been sat for about 8 weeks now
__________________
Old 21-11-2009, 10:31 PM   #6
cossyking
Trader Score: (0)
cossyking is on a distinguished road
Quote:
def steering uj mate take it off and wd it and free it off, it will be fine
cossyking is offline   Reply With Quote
Old 21-11-2009, 10:35 PM   #7
paul thornton
BMW RS DIESELWORTH
paul thornton's Avatar
Trader Score: (0)
paul thornton is an unknown quantity at this point
you need to take the uj off under the bonnet, drown it in penetrating oil and then work some high temp grease into it. Also replace the plastic bush that goes through the bulkhead. Mine was exactly the same,been ok for about 3 years now though after doing that.
paul thornton is offline   Reply With Quote
Old 21-11-2009, 10:55 PM   #8
Barry R
Barry R's Avatar
Trader Score: (3)
Cool then no need to scrap it lol
__________________
Old 22-11-2009, 12:39 PM   #9
Trader Score: (0)
As we NOW know that it was ok prior to being parked up for 8 weeks, it obviously won't be a bent rack, I don't think it's going to be the UJ, but it's free so worth a go lubing before moving on to other things.
You could dispense with power steering altogether if you wanted and go for a 2.2:1 quick rack manual(std 2wd cossie is 2.56:1), I've just installed this into Roosies manual rack housing, this will then need a smaller splined joint, but mk3 fiesta non power joint can be used.
Old 22-11-2009, 12:41 PM   #10
Barry R
Barry R's Avatar
Trader Score: (3)
Cool but is it heavy atall
__________________
Old 22-11-2009, 04:03 PM   #11
Trader Score: (0)
Don't know as engine out of car, under bonnet has just been painted, it will of course be heavy at slow parking type speeds but not a problem, just got to weld and make up a steering link now, fit hydraulic clutch and sequential gearbox!!
Old 22-11-2009, 04:52 PM   #12
Barry R
Barry R's Avatar
Trader Score: (3)
Fair play mate i thought stu had given up with the cossie scene lol
__________________
Old 23-11-2009, 12:52 PM   #13
Trader Score: (0)
So did he, but he got withdrawal symptoms!!
It's a good job Kayleigh doesn't know what he spends on it, otherwise he'd need to top up his health insurance!!
The 3 door is going to be a 100% dedicated track car, and running twin side exit pipes.
Old 23-11-2009, 12:52 PM   #14
Trader Score: (0)
Old 23-11-2009, 02:44 PM   #15
Barry R
Barry R's Avatar
Trader Score: (3)
Fair play to him then.
Whats he doin with his saph now then?
Is he gona track that aswell? or road go it?
__________________
Old 23-11-2009, 07:01 PM   #16
Trader Score: (0)
The sapphs going to be a road only car, but no doubt he will do some track days in it, he also has a SAXO(chav) beemer 330d, motorhome, transit van, as well as his 3 door and sapph.
He's got too much to do and not enough time, the usual problem for most!!
Old 23-11-2009, 07:24 PM   #17
Barry R
Barry R's Avatar
Trader Score: (3)
lol fukin hell only a few then
__________________
Old 24-11-2009, 06:02 PM   #18
Rs_Nick
Trader Score: (0)
Rs_Nick is an unknown quantity at this point
Send a message via MSN to Rs_Nick
Hi mate's
The steering from my cos 4x4 is also stiff.
I read this topic but realy don't know what you mean with UJ.
Can somebody please explain what a UJ is? My English isn't as good as I want it to be.
Thanks!
Rs_Nick is offline   Reply With Quote
Old 24-11-2009, 07:26 PM   #19
Barry R
Barry R's Avatar
Trader Score: (3)
ive changed the bush and checked the UJ and the steering feels a little bit better but it snatches now ??????????
__________________
Old 24-11-2009, 07:32 PM   #20
Barry R
Barry R's Avatar
Trader Score: (3)
the uj is the wobbly part that connects the rack to the column
__________________
Old 25-11-2009, 05:56 AM   #21
English
English's Avatar
Trader Score: (0)
English is on a distinguished road
It means Universal Joint - as above, it's the flexible part at the bottom end of the steering column inside the engine bay that bolts to the steering column at the top, and to the steering rack at the bottom.
My rubber bush in my UJ shat itself, so replaced with a eurathene one from Superflex - from the MK1 Escort kit. Had to buy a couple of different nylock bolts to make it fit my 2wd Saff. Plus changed the steering column bush at the same time. It's gonna be glorious when I get to drive it again. Been off the road for 11 months and counting. Sadness
English is offline   Reply With Quote
Old 25-11-2009, 06:01 PM   #22
Rs_Nick
Trader Score: (0)
Thank U mate,
Tomorrow i've gone look at this part. And set it in the wd.
Old 25-11-2009, 06:04 PM   #23
Trader Score: (0)
Superflex now supply a dedicated 2wd cossie flexy bit in 10mm poly, cost £45 in uk, superflex don't make any bushes, they are made by Pro Sport in austrailia.
I do know there is soon to be another uk supplier offering the same bit substantially cheaper, as well as other cossie parts.
Old 25-11-2009, 09:47 PM   #24
Barry R
Barry R's Avatar
Trader Score: (3)
Cool
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
stiff steering Maxxeh Ford Escort RS Turbo 17 08-01-2007 11:50 PM
frst steering stiff sy16v Ford Fiesta Rs1800 & Rs Turbo 4 16-08-2006 11:40 PM
Please help,i have stiff one Anonymous General Car Related Discussion. 6 31-10-2005 07:23 PM
stiff steering johnnymac Ford Sierra / Sapphire / RS500 Cosworth 2 24-10-2005 10:34 PM
How stiff am i?? g4ost General Car Related Discussion. 7 27-10-2004 10:15 PM
