PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Sierra / Sapphire / RS500 Cosworth
Register Forgot Password?
Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 27-07-2009, 12:39 AM   #1
florent78
Trader Score: (1)
florent78 is an unknown quantity at this point
Default polybush the rear arm need review from those who do it
I have some play with 1 wheel
the outer original bush sames to be dead
I do some search and read pationate post
some guys tell NO polybush for the rear arm, only original cause it's spherical inside
as you can see on the picture, not sure it's true (picture comes from a restauration post)
my question is simple :
for those who put powerflex bushes (the strongest) for the rear arm
you feel it's great or after you find that handling was bad and you regreat original bushes
thanks
florent78 is offline   Reply With Quote
Old 27-07-2009, 10:46 AM   #2
Mr C
Trader Score: (2)
Mr C is an unknown quantity at this point
from what I have driven if the rear arms are poly bushed they are not as tight a rear end as rose jointed or even std Ford joints, Ford parts are mega expensive though so thats why you see a lot poly bushed instead.
I think with a bit more metal in them poly would be brilliant but they text to move/wander around a bit much- gives a vague feel
__________________
MSD L8, 1/4mile 14.3@98MPH 2.3sec-60ft on 11PSI-260BHP? And 10 yr old rubber.
COSSIE ON ICE
http://www.youtube.com/watch?v=RwPZDlY7Z0A
Mr C is offline   Reply With Quote
Old 27-07-2009, 11:37 AM   #3
charlie luciano
charlie luciano's Avatar
Trader Score: (3)
charlie luciano is on a distinguished road
Send a message via MSN to charlie luciano
Unfortunately its going to be a matter of having to polybushing the rear trail arms at some point as the outer ones are nla from ford the inner bushes are still available @ £75 each plus the vodka and tonic
Luciano
__________________
Middlesex RSOC's Front Man
www.sccperformance.com
www.madevelopments.com
www.middx-rsoc.co.uk
charlie luciano is offline   Reply With Quote
Old 27-07-2009, 12:19 PM   #4
sabres74
sabres74's Avatar
Trader Score: (0)
sabres74 is an unknown quantity at this point
thanks
Best thing you can do, mine is polybushed all round and handles like a dream
__________________
www.fordmotorsportmodels.com
sabres74 is offline   Reply With Quote
Old 27-07-2009, 12:41 PM   #5
Paul_RS
Paul_RS's Avatar
Trader Score: (4)
Paul_RS is an unknown quantity at this point
Send a message via MSN to Paul_RS
http://www.grahamgoode.com/
Graham goode seem to be remaking the bushes.....
__________________
Paul_RS is offline   Reply With Quote
Old 27-07-2009, 03:55 PM   #6
florent78
Trader Score: (1)
I think I will buy poly bushes (powerflex)
powerflex can be yellow, purple or black (stiffer to stronger)
not sure you can have the rear arm bushes in every color
for those who buy powerflex, they come in yellow or purple ?
thanks
Old 27-07-2009, 04:14 PM   #7
col93saphcos
col93saphcos's Avatar
Trader Score: (1)
col93saphcos is an unknown quantity at this point
ggr doing both trailing arm bushes,sounds like there servicable to,will be trying the outer ones very soon,think about £80 each
col93saphcos is offline   Reply With Quote
Old 27-07-2009, 08:14 PM   #8
Saaamon
Saaamon's Avatar
Trader Score: (2)
Saaamon is an unknown quantity at this point
Send a message via MSN to Saaamon
thanks
Don't think it works like that pal, on my old 850 i had to use purple engine mounts and on my mates s70 he had to use yellow one's. Its all down to the material the bush sit in.
Saaamon is offline   Reply With Quote
Old 27-07-2009, 09:21 PM   #9
RS-Stian
www.fordclubnorway.no
RS-Stian's Avatar
Trader Score: (1)
RS-Stian is an unknown quantity at this point
I have black Powerflex bushes in the trailing arms on my cos, don't know if these are any stiffer than the yellow ones?
RS-Stian is offline   Reply With Quote
Old 28-07-2009, 10:00 AM   #10
Trader Score: (0)
tabetha will become famous soon enough
Some people who supply poly bushes do use different colours to denote hardness, it's only a colour that is added.
It is possible to get the bushes in ANY colour from certain people though, it is also possible to beef up standard bushes using hard grade poly where any voids exist such as rear diff hanger.
My mate is supplying someone with seriously beefed up engine and gearbox mounts, by filling the void with a shore 90 poly, this has excellent tear/shear characteristics, and the feedback word of "awsome" is most used.
They guy who is having the mounts beefed up wanted yellow bushes so a batch are being done in yellow to suit all his suspension powder coated bits.
Powerflex are seriously overpriced, for the materials used, there is no reason technically or otherwise why for example flo flex, superflex and similar will be any different material wise, my mate has shit loads of the stuff delivered and the company he uses do research into any "unique" properties that some bushes might have, not found any difference from any maker yet from one to another.
It is even possible to have multi coloured bushes, but they are not for structural use, more just aesthetic as have to be cured seperate(colour wise) so not strong just for show.
tabetha is offline   Reply With Quote
Old 29-07-2009, 09:41 AM   #11
florent78
Trader Score: (1)
I buy the powerflex finally
for information (I ask powerflex)
yellow have a shore of 70
purple have a shore of 80
black have a shore of 95 (they are 20 % more expensive)
I take the black
I buy them on
DCDezign - Performance Car Parts
http://www.DCDezign.com
He accept to do the same price as matt lewis (54£ for a pair of bushes)
I aggree powerflex are not ship
but you know the shore
can someone give the shore for the others (deflex floflex ......)
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
series 1 or 2 rear end polybush kit milesy23rst Ford RS Turbo parts for sale 4 06-02-2009 11:07 AM
Rear arm bushes sapph1 Ford Sierra / Sapphire / RS500 Cosworth 15 25-11-2008 01:17 PM
rear trailing arm krisberic Ford Sierra / Sapphire / RS500 Cosworth 13 08-07-2007 10:40 PM
Rear Suspension Arm ? JimmyBoy Ford Escort RS Turbo 5 20-03-2007 08:30 PM
10,9 REAR ARM BOLTS cos jon General Car Related Discussion. 2 19-08-2006 05:46 PM
