| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Sierra / Sapphire / RS500 Cosworth This forum is for discussion of all things pertaining to the Ford Sierra Cosworth. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
Kind regards Jan |
#2 |
More boost Igor!
Yes - if it's completely broken it'll go to over 4000 (mine did when it fried).
An air leak at the inlet manifold will also increase revs. |
#3 |
Hell yeah it can.
#4 |
Alive
Yup
#5 |
hmm.. it says "click" when connecting with ignition on or startet engine.. if startet it gets mad.
So I can be 211% sure that it is not another sensor causing the ecu to tell the iscv to go "high"?? What causes it to give up life ??
__________________
Kind regards Jan |
#6 |
They always cause problems with sticking, normally socking them in petrol over night clears them out, however you are right thinking it may be other problems, as you have said when you unplug it the idle drops, so I would say it may be being told to open this much. Does the speed not drop at all even when hot?
Martin |
#7 |
i had my cossie in storage and only drove it once a month if i was lucky and used to tick over at 3000rpm for first few miles then would drop
#8 |
![]() BANNED |
It could admit enough air to redline the engine with no load on it, just do the spraying etc then wop 12V into it from a battery, this frees them up nicely.
If this doesn't work you know it's a sensor telling it to do the revs. tabetha |
#9 | |
Quote:
Nope By the way, the iscv is relatively new, and I do know it dosnt make it last forever (new parts do break to) but I did give it a clean a few days before, and it work for one drive.
__________________
Kind regards Jan |
#10 | |
Quote:
I agree with you.. so far I see logic... but following guides found here an dthere on passionford and THE WORKSHOP MANUAL, everything has the correct value. One thing though... I have tried 2 extra tps I have, and all give the same value. I cant get them to give me LESS than .38v (my papers says .6V with closed throttlebody) I remember it is .5V at the moment. And properly most important.. I dosnt make fuelcut when letting go of the throttle, and thats is NOT right, so at the moment I am sourcing a factory new tps and changing it on suspicion. It is not the first time I have doubt about the tps being faulty and not showing it when testing. I also remember something about the tps being a kind of in direct connection (via ecu ofcause) with the iscv, have you heard of this???
__________________
Kind regards Jan |
#11 |
Trader Score: (0)
Rep Power: 12 ![]() |
took mine apart and unsonic cleaned erm same as my injector
worth getting the cheap unltrasonice as the new icv can cost Ł92
__________________
![]() RS500 fully balanced blueprinted bd14 8x 803 racing loom coil pack verns Field Motorsport ***BHP FORGET SECs T4 Air2Air koni Ahmed springs Samco Pectel monitor poly bush WITH SOME EXTRA and I HAVE A SAFF 4x4 :Op more to follow !!www.grovegarage.com www.fieldmotorsport.com www.roosemotorsport.co.uk www.turbodevelopments.co.uk www.diamondinsurance.net http://members.lycos.co.uk/rscosworth/ |
#12 |
__________________
Kind regards Jan |
#13 |
Thinking Cosworth..
Had this problem when my TPS was set at a wrong value. When setting it at 0.35V or higer it would rise the idle speed up over 2000 RPM. After setting it at 0.30V everything was fine.
__________________
__________ Cheers, Wim ************************************************** ******************** Cossie 4x4 1991, MSD CLOSED LOOP CONVERSION ************************************************** ******************** |
#14 |
Trader Score: (1)
Rep Power: 33 ![]() |
I had a fault on my cossie,when i used to drive it from cold it felt like the choke was sticking on and the car used to drive on its own when i took my foot of the throttle.I got told to take the ISCV out and lub it up with brake fluid.It has worked a treat.Its stopped doing the fault and the revs also dont go up and down from cold either.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#15 |
I tried setting my tps several times these days.. .4v .35v .3v .. tomorrow to let the spring in the tps set it, and give it a go.
__________________
Kind regards Jan |
#16 |
Yes the ISCV is capable to rev the car to 2500rpm and also the TPS issue is a possible cause so the ISCV receives wrong signal from the ECU...
#17 |
fixed!! I set the tps to 170mV as the tps-spring trick didnt fix it. It had instantly normal idle and it fuelcuts when letting of the foot, and that must mean the ecu get it requiered idlesignal.
__________________
Kind regards Jan |
#18 |
Trader Score: (1)
Nice one mate glad you sorted it.
__________________
#19 |
Thank you
__________________
Kind regards Jan |
#20 |
Drifter
my idle is at roughly 1700 Rpm at all times, hot cold etc... what is the correct idle speed, mine is a stage 3 set up..
Ste |
#21 | |
More boost Igor!
Quote:
Disconnect your ISCV and see if the idle drops - should drop to more-or-less the correct idle speed. If it drops, then your ISCV is either gunged up and stuck open or broken. If it stays high, then you might have a leak somewhere on the inlet side, maybe a blown inlet manifold, plenum or throttle body gasket, or slightly more likely, a split or loose-fitting hose on the inlet side. Last edited by cozmeister; 06-07-2009 at 04:13 PM. |
#22 |
Instead of starting a new thread I'll ask here
My three door is starting to have idle (and starting) issues ... but only when warm. When warm the idle is either smooth but at 1500 rpm, or irregular / rough at 1000 rpm. Also starting the car when warm it seems to be taking a while to get fuel (just ticks over) I counter this but letting the system prime from the fuel pump before firing. Cold start is fine. I dont think the erratic idle is caused by an airleak because it goes from high to low (not constantly high)
__________________
Moser my Moonstone 3 Door ... http://www.passionford.com/forum/viewtopic.php?t=296926 |
#23 |
![]() BANNED |
If you haven't in a few years changed the CTS do so now, as it's so important, then set co to what it should be for the chip you are using ?
Disconnect the iscv, and set base idle to around 900 rpm, with all electrics off, engine apart and FULLY warmed up. tabetha |
#24 |
#25 |
Thanks (again
... I'll give it a go ... and let all know. and yeah all 20 y/o shonky sensors still installed!
__________________
#26 |
Guys looks like i've got the same issue.
When i disconnect the ISCV the revs drop to normal level. Quick question though, what sort of damage would be caused if i were to drive with the iscv disconnected?
__________________
Pri |
#27 |
^^ Posted on your other thread.
Martin |
#28 | |
More boost Igor!
Quote:
If the PF01 TPS is broken, and sending a low voltage to the ECU even though the throttle's closed, the ECU will assume you've planted your foot on the throttle because the PF01 output drops as the throttle opens. If your Idle control valve is also stuck open, maybe because it's gummed up or because of an electrical fault, there'll be enough air flowing through for the revs to rise that high. Last edited by cozmeister; 21-04-2010 at 03:55 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Revs to 2500 then cuts out? | Asturias | Ford Sierra / Sapphire / RS500 Cosworth | 1 | 11-06-2009 06:03 PM |
| High Rpm... | Bakster | Ford Escort RS Turbo | 4 | 14-04-2007 07:40 PM |
| high revs on idle | grsford | Ford Escort RS Turbo | 11 | 11-11-2006 03:42 PM |
| high rpm | K500BHP | Technical help Q & A | 0 | 27-10-2005 06:30 PM |
| RS Turbo s2 wont run under 2000-2500 rpm !help! | truesrob | Technical help Q & A | 8 | 24-11-2004 08:54 AM |
