high revs
To set idle speed let the car come to operating temp then disconnect ISCV and use the screw under boost pipe on throttle body to set idle.
There is a lock nut on this screw.
The above is how to set HOT idle, the raised COLD idle speed is controlled by the ecu/chip, mainly from the CTS reading, ie the colder it says the engine is the faster it will idle.
07-10-2015 12:56 PM
