Just been a muppet and dropped one of my pistons.
Old 03-06-2008, 09:30 PM
L33 BYT
L33 BYT's Avatar
Default Just been a muppet and dropped one of my pistons.
Silly mistake. Arrived today. went to put them in the garage and one fell of the shelf.
It has this little mark on it now, will it be ok? Could it be repaired? Is this now scrap?
Dam it.
Thanks
Lee
Old 03-06-2008, 09:46 PM
JTECH James
Passion for Fords!
JTECH James's Avatar
take it into a machine shop,let them check and clean it up....should be ok,as long as it doesnt catch the bore
Old 03-06-2008, 09:53 PM
rapidcossie
rapidcossie's Avatar
As said it really depends how bad it is as the skirt might now catch the bore.
If it was me i would say it arrived like this and delete this thread!
Old 03-06-2008, 09:55 PM
AndyPen
AndyPen's Avatar
Doubt if that little ding has distorted anything - as suggested, get any burrs removed (if any) and it will be fine... just be careful with them when you take them
Old 04-06-2008, 05:23 AM
Stop worrying, just use a bit of emery to take off sharp edges, it's nothing, or bring down and I'll spin it in the lathe for you if that fussed, personally a bit of emery for me, then a good wash.
Old 04-06-2008, 05:29 AM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
As above, just rub it down until you no longer feel a ridge on your fingernail.
Old 04-06-2008, 08:39 AM
L33 BYT
L33 BYT's Avatar
Tabetha, I may take you up on that if your ok with it.
when I touch the skirt I can feel a little imperfection.
Old 04-06-2008, 04:23 PM
If you are still worried just get a thin piece of wood about 1 " wide and glue a bit of emery to it then use as a flat board for taking out mark.
Old 04-06-2008, 05:21 PM
JTECH James
Passion for Fords!
may i suggest one of your mrs finest nail files
Old 04-06-2008, 05:27 PM
Chip
*** Sierra RS Custard ***
Chip's Avatar
All that matters is it doesnt stick OUT, it doesnt matter at all if there is a little dent in.
So as Tabby says just dress it back, problem solved.
And dont be such a clumsy twat next time
Old 04-06-2008, 05:47 PM
L33 BYT
L33 BYT's Avatar
Mate dont worry I gave my self a proper beating
Old 04-06-2008, 07:19 PM
smartrs
smartrs's Avatar
muppet there compleatly fucked and totally not useable on your re-build !! i've got a set here i'll swap you for them so you can carry on
Old 04-06-2008, 07:35 PM
L33 BYT
L33 BYT's Avatar
All sorted mate.
I think
So put that in your pipe and smoke it.
Marv888
26-09-2015 03:44 PM
Andypandy260
23-09-2015 10:28 PM
Quick Reply: Just been a muppet and dropped one of my pistons.
