Sapphire front bumper removal
Old 28-05-2008, 09:07 AM
Paulo P
Paulo P's Avatar
Default Sapphire front bumper removal
I've got a new front bumper to fit to my sapph because the old one is a bit tired but I've got no idea how to remove it and I've not had time to look yet How hard are they to change and where does the rail bolt to the chassis? I know you've got the side mounts but I've not found the bolts for the rail yet.
Thanks
Old 28-05-2008, 03:57 PM
Matt Baxter
Back in black!
Matt Baxter's Avatar
Thanks
you wont because the bumper is only slides in to the rails
Old 28-05-2008, 04:29 PM
MARCOSWORTH
MARCOSWORTH's Avatar
Mine has bolts in the rail,horns are connected to it
Old 28-05-2008, 05:29 PM
Although the horn is bolted into the rail the square tubes are too short for the bolts position to go through them.
Old 28-05-2008, 06:59 PM
Paulo P
Paulo P's Avatar
so is it only bolted on at the sides?
Old 28-05-2008, 07:07 PM
neil andeRSon
neil andeRSon's Avatar
Smile
yup. should just pull outta the chassis leg's on rubber block's.just watch for the spotlight wires.
Old 28-05-2008, 07:55 PM
Paulo P
Paulo P's Avatar
That sounds alot easier than I was thinking, no wonder I couldn't find the chassis rail bolts
Fog light wires are long gone hence another reason to change the bumper
Thanks
Old 29-05-2008, 06:16 AM
THEORY is nice, PRACTICE is often different.
The thorugh bolts onto the side supports seize, nearly always, and sometimes you have to be forceful and yank them off, breaking as little as posible in the process.
There is a easy cheap, less than £1 cure that will fix the problem PERMANENTLY though so don't despair, if you need to be a bit brutal.
Free off the height adjusters whilst the bumper is off as a lot easier to do then!
Old 29-05-2008, 07:25 AM
dojj
Resident Wrestling Legend
dojj's Avatar
if you want to improve the security and stop little scrotes from having your bumper off by just undoing 2 bolts, remove the headlights and find the location for the height adjusters in the chassis legs
drill a small hole through the leg and adjuster then put a self tapping bolt through the hole
the headlights will cover the bolt heads and no one will be any the wiser
Old 29-05-2008, 09:23 AM
Paulo P
Paulo P's Avatar
Nice tips guys I can't believe that the bumper is only held on by 2 bolts I'm used to Subaru's where you have to remove pretty much the entire front end and shear loads of bolts in the process
The replacement bumper has a side mount broken so I'm hoping and praying I can salvage the mounts on my old bumper and replace the broken one.
Old 29-05-2008, 01:46 PM
You can take the whole side panel fixing bit off, just drill out the rivetts and then re revitt, if you are careful you can reuse your existing trim piece as well.
Old 29-05-2008, 04:49 PM
neil andeRSon
i've had to glue mine. did it over a year ago so it'll hopefully be hard now!!. but luckily i bought a new moulding yr's ago so gonna have one nice standard bumper an one modified one...
Old 31-05-2008, 02:47 PM
groomers
groomers's Avatar
hwats this about height adjusters?
Old 15-06-2008, 08:48 AM
Mike1
Mike1's Avatar
Hi Tabetha
Could you tell me more about the £1 cure please?
Old 16-06-2008, 09:31 AM
XRT_si
XRT_si's Avatar
My bumper sags down one side, does this mean the height adjuster has broken?
Old 28-06-2008, 05:42 PM
Mike1
Mike1's Avatar
Hi Tabetha
Any more news on the £1 cure?
jessie_rs
11
03-06-2019 04:57 PM
andy130
15-03-2016 07:59 AM
Gary @ RS CLASSICS
11
10-09-2015 06:49 AM
C2 MAK
20-08-2015 09:46 PM
Quick Reply: Sapphire front bumper removal
