Water temps
Old 23-05-2008, 06:50 PM
Tev
Tev's Avatar
Default Water temps
right whats the average water running temps 4 a cosworth (i know all engines r different) but according to my secs monitor my water temps at the back of my head stays around 80does this sound bout right?
Old 23-05-2008, 07:04 PM
rapidcossie
rapidcossie's Avatar
sounds about right on an easy cruise.
Old 23-05-2008, 07:06 PM
charlie luciano
charlie luciano's Avatar
I know that the fans kick in at 87 degrees so it might be static at 80, not too sure though
Luciano
Old 23-05-2008, 07:58 PM
Tev
Tev's Avatar
yer thats what i was thinkin, its sittin at that temp on the motorway
Old 23-05-2008, 08:17 PM
rapidcossie
you find that on a cruise water and oil temps are almost idendical due to the modine heat exchanger
Old 23-05-2008, 08:38 PM
sounds ok to me as long as the fans cut in dont worry about it.
Old 24-05-2008, 05:59 AM
As glenshute says, ok to me too, shows the stat is working as well.
Oil temps will be higher, why they are cooled by modine, the oil does at least as much cooling as the water.
Old 24-05-2008, 08:47 AM
Tev
Tev's Avatar
Cheers guys
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
DAZZER
30-09-2015 08:43 PM
Quick Reply: Water temps
