Sump plugs..??
Old 22-05-2008, 02:52 PM
cosrep
cosrep's Avatar
Default Sump plugs..??
Can anyone tell me if the 2wd and 4wd sump plugs are the same..?? and what size is the tread of the the sump plugs..??
Old 22-05-2008, 06:26 PM
captiva
captiva's Avatar
You should use Honda Civic ones as they have a much larger hexaganol on them and the spanner does not round them off. It is the exact same thread and use the Honda aluminum washer too.
Old 23-05-2008, 05:27 PM
cossie604
cossie604's Avatar
If this is becuase you have stripped the threads then the easiest repair is to buy a m16 tap and a suitable drill bit and re-thread it to this size then buy a peugeot sump plig that is visualy the same as a standard cossie bung ie 13mm hex but with a 16m thread over a standard 14mm. Shouldnt be any need to go bigger in the spanner size for a sump plug if your torquing it up correctly....vauxhalls use a T45 torx and they do just fine if not over tightened and thats alot smaller than a 13mm spanner.
Old 24-05-2008, 12:34 PM
cosrep
cosrep's Avatar
So a standard 2wd/4wd sump plug is a M14 tread?
Old 24-05-2008, 02:30 PM
dazzle740
dazzle740's Avatar
definately m14 on 2wd drive i just changed mine
Old 24-05-2008, 04:42 PM
cossie604
cossie604's Avatar
lol just noticed what i wrote....if you do it how I said, you'd be after a peugeot sump plug...sump plig's aint suitable
Iain Mac
30-09-2015 09:39 PM
youngben
27-09-2015 09:37 PM
little bram
21-09-2015 02:50 PM
BRAM
08-09-2015 07:11 AM
little bram
07-09-2015 11:59 AM
Quick Reply: Sump plugs..??
