compression ????
Old 19-05-2008, 07:10 PM
SWIFTY
SWIFTY's Avatar
Default compression ????
my mate just done a compression test on his car an one reading was 18psi lower than the other 3 is that anything to worry about the car is runing ok and no smoke.
thanks
Old 20-05-2008, 05:31 AM
Not worth worrying about, especially if it has a few miles.
In an IDEAL world they would all be within 10% of each other, but I wouldn't personally bother about 18%, as it means stripping bits down.
You could always do a dry then wet test to see if it is rings of valves, it is most likely valves,(or just the tester did not make a good seal on the low one).
What car is it anyway.
Old 20-05-2008, 03:34 PM
SWIFTY
SWIFTY's Avatar
Thanks Ill Tell Him
Its A 2wd Sapphire Cosworth Its Been Rebuilt Not To Long Back
Prickly_buzz
07-12-2017 09:52 PM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
IainRS1700T
25-09-2015 06:44 AM
RS-Rikki
21-09-2015 07:27 AM
Quick Reply: compression ????
