cam cover info please
Just bought a replacment cam cover for my 1989 sapphire 2WD.
What is the size the bolts and what are they called any tip on what order to tighten ect, Many thanks
The blots are M6, not sure on length, but I just do them up starting from front to rear, DON'T overtighten othrwise it will distort the cover and leaks will occur, use a COMETIC rocker cover gasket from Matt Lewis 01922 692424, they are ace reuseable and don't leak, use new half moons as well, with sealant just around the ends where they meet the r/c gasket and the underside of the front cam caps.
A "T" handle would be much quicker but yes a normal allen key will work, 5mm I think it is.
Or a allen driver bit and a 1/4 ratchet etc.
Yes on mine they were/are all cap heads(allen) bolts.
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
