2WD clutch ratchets??
wondering if anyone can give me some advice got a 3dr cossie which ive just put back on road, fitted new standard clutch kit while engine out (genuine ford) and a new ford clutch cable 2wd and had a problem with the biting point to low and couldnt get gears. so fitted new clutch quadrant kit and still the same, if i manually adjust it then its ok untill i knock the pedal and then its gone shitty again any ideas????
Mine was like this to start with, but 500 miles later was normal.
Did you fit the gearbox end first, have you tried to reset the auto adjuster, by lifting pedal and pushing the quadrant away, then releasing pedal ?
