Removal of the Rear trims on the quarter panel
How do you remove the rear black plastic trims on the quarter of a saff. The ones next to the rear screen. Mine are showing signs of ageing so i thought i would freshen them up with a coat of satin black
Cheers all
Cheers all
remove the c pillar trims from the inside mate, they have 2 screws in and clip off. You also need to remove the rear shelf by undoing the screws and pull the shelf forward to release it from its clips under the rear screen. You will then see 3 plastic nuts on the inside for the outer trims. Undo them and Bobs your uncle and all that.
HTH
HTH
HTH
HTH
paceo
12
04-08-2015 08:50 PM
