Cossie misfire
Old 11-05-2008, 09:49 AM
timster
timster's Avatar
Default Cossie misfire
Hi everyone my 4x4 cossie has developed a misfire at low revs i.e. 20mph 2nd gear,seems okay when you put it to go anyone else had this?Took the cap and rotar arm off yesterday they looked fine and sprayed some electrical contact cleaner on the multiplugs in the engine bay.Thanks for any help in advance
Old 11-05-2008, 01:08 PM
mechanic28
mechanic28's Avatar
what plugs have u got fitted?
Old 11-05-2008, 01:12 PM
KSA-Cossie
KSA-Cossie's Avatar
And what gap ?
Old 11-05-2008, 02:19 PM
timster
timster's Avatar
The pp8 ones,0.7 gap.
Old 11-05-2008, 02:21 PM
What is the CO set to ?
Old 11-05-2008, 04:12 PM
timster
timster's Avatar
0.5% one of stu's closed loop stage one,the plugs are brand new
Old 11-05-2008, 04:24 PM
KSA-Cossie
KSA-Cossie's Avatar
Have you tried the old plugs back in m8 ?
Old 11-05-2008, 05:06 PM
timster
timster's Avatar
It was doing a similar thing before,might go down the route of changing the cps,phase sensor,ignition amplifier
Old 11-05-2008, 07:29 PM
Don't just change for the sake of it, check the switching speed of the Lambda.
Old 12-05-2008, 06:34 PM
costina
Live long and prosper!!
costina's Avatar
0.5 % is too low imo needs to be .8 .9 plugs gaps 0.6mm
Paul
Old 22-05-2008, 04:09 PM
timster
timster's Avatar
Used some contact cleaner on the multiplugs above the rockercover and used the car three days on the trot and its all good! no misfire since tuesday
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: Cossie misfire
