was coming home form work today, was giving it a bit down the bypass, but as i slowed down for the roundabout, i noticed the rev counter just dropped (the engine didnt stall) then just shot back up again, with a plume of smoke out the exhaust, this is the second time it has happened in about 6 months.
Clearly the ignition was interrupted, hence the smoke, the fact that you were slowing down, was why you did not notice a stalled engine as cars motion was turning the engine.
My mate discovered that his rotor arm did the occassional twist as it wasn't sitting properly. I'd check the dissy area for sure. How old are the sensors?
