help!battery warning light
assume its a saff?
make sure you check the connections to the back...i had no end of problems with mine; also worth checking the elecrtical component on the back of the alternator; held in with 2 10mm
is the alternator battery brand new? not wanting to make you look stupid but have you got enough tension on the alternator belts
check you've got good earths
what voltage have you got accross the battery while engine running? you should have 13.5 to 14v, also check the charge link wire on the alternator and to the back of clocks....
battery fooking died last night..
when ignition was turned on everything was fine until a few minutes of driving..i suspect the alterantor isnt charging the battery..battry was brand new.
got a pic of the alternator wiring..is it correct? any clue people
Dr. Ickxs
15-09-2015 10:15 PM
