Re-wiring Fans
Old 29-04-2008, 09:57 PM
Tev
Tev's Avatar
Default Re-wiring Fans
I noticed that the fan loom on my cars is starting to look a bit shabby so before the and after reading a artical stu wrote for fast ford ive decided its time to get the soldering iron out and do something about it,
What im after is advice on what i need (ie relays) and suggestions on how i go about doing it,
I notice in stus artical he suggests using a relay per fan, has any1 else done this?
any suggestions welcome ta
jay
Old 30-04-2008, 08:43 AM
oldford
oldford's Avatar
When you are using normal 30A or 40A relays it's a good ida to use one relay per fan.
Fan's draw a lot of current and the connectors and relay's can become very hot.
I always use high amps relays from Bosch: 0 332 002 156. With such a relay you only need one. It may seem to be overkill, but this relay will work forever.
It's a good idea to use the thermo switch in the radiator parallel with a switch and/or control from the ecu. It's also a good idea to power the relay directly from the battery, so it can cool the radiator even when the ignition is turned off.
see: http://www.keefeperformance.com/kprelay.html
Old 30-04-2008, 10:17 PM
Tev
Tev's Avatar
cheers fella
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Chas
05-10-2015 07:13 PM
rs_jim
03-10-2015 11:37 AM
simonmcf
22-09-2015 08:40 AM
mk1focus
Ford Fiesta
21-09-2015 05:46 PM
Quick Reply: Re-wiring Fans
