CO running at 11.5 - 12.0%!!!
Old 28-04-2008, 08:01 PM
mr_intex
mr_intex's Avatar
Cool CO running at 11.5 - 12.0%!!!
I am setting up my 1987 sierra cosworth 3 door and checked the co emissions today and it was 11.5 - 12.0%.
what should i be aiming for?
the car is running a stage 3 setup (330bhp).
many thanks
Old 28-04-2008, 08:07 PM
rapidcossie
rapidcossie's Avatar
emmisions at idle?
Old 28-04-2008, 08:28 PM
cossie604
cossie604's Avatar
personaly at idle i'd set it around 3-3.5
Old 28-04-2008, 08:41 PM
mr_intex
mr_intex's Avatar
Smile
emissions are at 900 - 1000 rpm.
many thanks
Old 28-04-2008, 08:44 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
2.5% unless it has good closed loop software in a L8 or P8 ECU, in which case around 0.8%
Old 29-04-2008, 05:18 PM
v man
Zee Germans are coming
v man's Avatar
fuck my car was benched by mr bajoo and it idles at 17% whats going on there i got greys but still cant be right
its going to the norris me thinks for a live map
Old 29-04-2008, 05:24 PM
costina
Live long and prosper!!
costina's Avatar
Ahmads chips always run mega rich for safety
I used to run greys and could not get it lower than 7% at idle
now run MSD closed loop 0.9% at 850 rpm
paul
Old 29-04-2008, 06:46 PM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
12%. Borewash will be an issue. Get it sorted
Old 29-04-2008, 06:53 PM
costina
costina's Avatar
bet it rattles bad too
Old 29-04-2008, 08:57 PM
mr_intex
mr_intex's Avatar
thank you for all your help!
i have setup the idle to between 900 - 1000 rpm and set the co at 3.3 - 3.7%.
all the best!
Old 29-04-2008, 08:59 PM
rapidcossie
MOT fail is 4% is it not?
Old 29-04-2008, 09:01 PM
KSA-Cossie
KSA-Cossie's Avatar
Just like mine does.
Old 30-04-2008, 07:17 AM
CossieRich
CossieRich's Avatar
all the best!
thats more like it. YOu need to get your fuelling checked when on boost as lowering the c/o at ldle affects fuel throughout the rev range.
Old 30-04-2008, 07:29 PM
v man
v man's Avatar
doesnt rattle at all mate can hardley notice its running apart from the exhaust
Old 30-04-2008, 07:47 PM
AndyPen
AndyPen's Avatar
Get it checked though mate - as said you could be making it much leaner at the top end as well and that means grief doesn't it!!
PJ Motorsport did me an MOT chip for my greys and cam set up. Maybe you could get something similar if needs be?
Good luck with it all
Old 01-05-2008, 12:26 AM
james kiely
james kiely's Avatar
is it possible to convert %co2 into g/kmco2 as the new car tax bands in ireland are based on g/kmc02,i just bought matts[silky 16v ,topman]saff which runs msds closed looped lambda conversion which seems to havea low co2.
Old 01-05-2008, 07:47 AM
foreigneRS
Testing the future
foreigneRS's Avatar
no, because co (carbon monoxide) percentage is a fraction of what the exhaust gases are made up of.
the amount of co2 (carbon dioxide) that a vehicle emits per km is a function of the fuel economy over a given test cycle.
completely different things and it would costs thousands to test an individual vehicle for g/km of co2
Old 01-05-2008, 10:31 PM
james kiely
thanx nick that clears that up
Old 02-05-2008, 11:58 AM
costina
costina's Avatar
It don't apply to car pre march 01(could be different in ireland)
Paul
`spotty
25-09-2015 11:41 PM
dombanks
21-09-2015 08:38 PM
tib2220
14-09-2015 12:33 PM
Eigdoog
13-09-2015 05:46 AM
Quick Reply: CO running at 11.5 - 12.0%!!!
