Big Breaks
Big Breaks
Ive got a 89 saph, and its been off the road while ive been rebuilding it, ive decided to uprate the breaks but im not sure what to go for, i have 17" kahns on it do i go 4pot 6 pot.
any makes and suppliers would be appreciated...so all help welcome .
Big Breaks
There Kahn RS-S 17" im sure a 330 dick would fit under them.
hope this helps to help me find what breaks to get...or i will just have to get different wheels to accomadate it lol
http://www.wheelsnthings.com/acatalog/KahnRSS.jpg
thanks
thanks
Depends on BUDGET as well.
You could always get brackets made to use 325mm FRS discs with your calipers, which will give you a sizeable step up in performance due to leverage.
thanks for the help... dunno if the 362 6 pots would fit under my rims, is here a way to use 6 pots and 330 disks ? thnks
Caraholic
Although the FRS Brembo callipers are pretty good, the FRS one piece discs are not really up to hard use, as they are unable to adequately dissipate the heat from a 1250kg car. Even the Focus warps it's discs on track, so a reasonably powered Sierra would do the same.
Obviously if the car wasn't going to be used on track, then this wouldn't be an issue, but them again, the standard items on a 2wd are good enough for fast road use if overhauled and braided hoses, good fluid and pads used, so you don't even need to go to the expense of that.
If you were going to use the FRS set up, then you would want the AP two piece brakes like Christian has put on his Escort RS Turbo - but then it's not a cheap option any more.
Brakes are a tricky thing to get right - doing it half way usually ends up with having to pay out twice (I found out the hard way on my own Sapphire all those years ago ), so always best to save up a little more and get the ones that will do the job in hand.
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
