How easy is it to fit injectors?
Old 11-04-2008, 02:54 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Default How easy is it to fit injectors?
Just bought a chip and some Greys for my car, wondering if I can fit the injectors myself??
Old 11-04-2008, 03:28 PM
dave green
dave green's Avatar
its easy, but anything is if you no how
dave
Old 11-04-2008, 03:33 PM
TurboShed
Cossiemodo
TurboShed's Avatar
dave
Let me re-phrase that, how do I do it and does it need any special tools? Will I fit them wrong and set fire to my engine bay?
Old 11-04-2008, 05:19 PM
Easy, unbolt fuel rail with two short 10mm bolts, careful as fuel pressure will still be present, use a rag over rail as you pull it off the injectors, but pressure soon goes.
Make sure to unplug the injectors first though, and slide off the clips, lift fuel rail, remove injectors from rail or inlet, which ever one they stick in, then use a bit of light oil on the seals of the new injectors, after checking them carefully for splits/worn sections, and refit in reverse order.
Check VERY carefully for leaks around the rail/injectors before driving off.
ps I assume you have the fitting kit that goes on the top of the injectors, otherwise they won't fit anyway.
Old 11-04-2008, 06:21 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Originally Posted by tabetha
...ps I assume you have the fitting kit that goes on the top of the injectors, otherwise they won't fit anyway.
Hi Tabetha, this is what I bought...
Old 11-04-2008, 09:44 PM
cossiegreg1
cossiegreg1's Avatar
I personally would give the chip and grey's to my tuner, and let him put them in, and then set it up properly.
Old 11-04-2008, 10:18 PM
ScORTED
Project Money Pit
ScORTED's Avatar
if your asking this question i'd say leave it to a pro
Old 11-04-2008, 10:25 PM
rsnissan
rsnissan's Avatar
your missing the fitting kit mate
Old 11-04-2008, 11:29 PM
SteveB
SteveB's Avatar
Fitting kit is there (2 metal rings and rubber on inlet side and 1 spacer and rubber on outlet side) and at least the end caps aren't present as you see sooo many with end cap on greys and light blues which fuck the spray pattern up into more of a dribble
Old 12-04-2008, 05:18 AM
As said it's all there, save some money fit yourself, unless miules and miles away from set up place, will only need fuel pressure(?) co tweaking anyway, just drive gentle till you get there, but otherwise it is only about 20/30 mins for tuner to fit stuff so if not sure ?
manuel boeckx
13
03-10-2015 02:29 PM
wheelwizardrefurbs
29-08-2015 09:25 AM
Roosie
13-08-2015 09:38 AM
track.focus'd
12-08-2015 05:53 PM
Perfmr2
06-08-2015 07:30 AM
Quick Reply: How easy is it to fit injectors?
