Gearbox oil
Diff use 75/90 semi or full synthetic 1 ltrs
Note diff MUST, use LSD oil, not just general oil.
A T5 box is normally used with ATF, ATF then attacks the pads on the selector forks ends as these are made from compressed paper/card, GEAR OIL doesn't do this and is why I use it, a 70 weight.
Location: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
I thought the LSD in the sierra was a sealed unit, therefore you dont need a specail lsd oil?? The gear oil in the diff wont come into contact with the LSD unit itself.
I also thought that ford put ATF in the T% box from the factory? So you use a 70 weight gear oil in you T5 box tabetha?
TPM961
15-01-2018 10:50 AM
Adam Graham
06-09-2015 06:04 AM
