fuel pump re-wire 4x4 saff
Old 04-04-2008, 03:22 PM
gaz4x4cos
gaz4x4cos's Avatar
Question fuel pump re-wire 4x4 saff
routed the wire through car etc , need to know the best way to do the connection at the pump (standard pump )??? , don't really want relay & wire's all over the place looking a mess . how have you done yours ?
Old 04-04-2008, 09:58 PM
mechanic28
mechanic28's Avatar
i just followed the original wiring path with mine u have to drop the tank down abit tho
Old 04-04-2008, 10:06 PM
LHD220Turbo
LHD220Turbo's Avatar
here you go fella, this might help
https://passionford.com/forum/general-car-related-discussion/227107-fuel-pump-re-wire-question.html
Old 04-04-2008, 10:11 PM
AndyPen
AndyPen's Avatar
Thats how mine was done by PJ motorsport
Old 05-04-2008, 08:28 AM
gaz4x4cos
gaz4x4cos's Avatar
Thumbs up
thats great , just want to ask a couple of thing's , do i use the red/blk feed which is coming out of the fuel cut off switch to keep in the circuit or bypass it ? do i need any special terminals to connect new wires to the pump ?
Old 05-04-2008, 08:36 AM
cossie04
cossie04's Avatar
When i re wired my fuel pump, i connected the wire to the black/red into the fuel cut off switch...
Old 05-04-2008, 09:04 AM
gaz4x4cos
gaz4x4cos's Avatar
i get what you mean and that would be alot easier that way ,but i read somewhere that its the wire itsself that goes out to the pump which deteriorates so by leaving this in would it not be defeating the object of the re-wire coz it leaving in a weak cable ??? or am i looking to deeply into it ?
Old 05-04-2008, 01:07 PM
mechanic28
mechanic28's Avatar
u can still get the original wiring with the correct terminals if u keeping your original fuel pump i have them but never used them can give u the part number if u like?how i done mine is have a fused live from the battery all the way to the back then using the red black wire coming out of the fuel cut off switch in the boot under the spare wheel(2wd not sure if it the same on a 4x4?)used that as the feed for my switching side on my new relay the original earth for the pump i used for the earthing side for the switching side!(this way the fuel cut off switch is still in the circuit!)the used the brand new feed to the new relay brand newe live from relay to pump and new earth(earthed mine out on the rear anti roll bar mount!) hope this helps?
Old 05-04-2008, 03:31 PM
LHD220Turbo
i rewired mine today and used all new cable to be on the safe side, i'm now running a 044 pump!
Old 05-04-2008, 03:36 PM
KSA-Cossie
KSA-Cossie's Avatar
Same as i did m8,best thing to do.
Old 05-04-2008, 03:42 PM
LHD220Turbo
slightly off topic but i noticed the 044 makes more noise than the standard item, i assumed this is normal?
Old 05-04-2008, 03:44 PM
KSA-Cossie
KSA-Cossie's Avatar
Same here m8.
Old 05-04-2008, 03:46 PM
LHD220Turbo
cheers
Old 06-05-2008, 09:27 AM
gaz4x4cos
gaz4x4cos's Avatar
don't suppose you have them part numbers for connectors do u , ford reckon they are not available anymore , god they are helpful in the parts dept . !
Old 06-05-2008, 04:59 PM
BIG WULL
Fae the Dale
BIG WULL's Avatar
I was thinking.. Could take a battery feed for the new relay from my sub, already in the boot??
Obviously would make a good job of it, fused seperatly and use a decent h/d connection block.
Does anyone think that would be ok? or not?
Old 06-05-2008, 05:18 PM
RSDOHC
RSDOHC's Avatar
can someone explane me why schould I rewire the fuel pump on my saph 4x4
Old 06-05-2008, 05:35 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Because the original wiring wears out, so the pump pumps less well, so you underfuel, and melt a piston, hurrah!
Old 06-05-2008, 05:43 PM
I would NOT use a amp supply cable as these draw lots of current so it will dip, when music whacked up, safer to use seperate supply.
The purpose of a rewire is to eliminate any old high resistance that may be present in the up to 22 year old wiring, on cossies, as any(DC) electrical motor(fuel pump) is VERY voltage sensitive and if it slows down your fuel supply gets low, sometimes low enough to do damage.
I put the relays on the area at the back of the nearside rear seat , up near the turret top as there is already a nice convenient 8mm hold there to hold the relay holder, AND if going to show or suchlike, you need only pull the relay for extra free security.
A group a pump at full chat draws 13 amps, so 28/030 is plenty big enough, I use 32/020 thinwall wire myself.
mint_s2
02-09-2015 08:58 AM
Ben26
01-09-2015 06:29 AM
ekjim
27-08-2015 05:20 PM
Prickly_buzz
25-08-2015 11:33 AM
kosienutter
31
22-08-2015 09:55 AM
Quick Reply: fuel pump re-wire 4x4 saff
