little bit of a running problem after a ragging
Old 03-04-2008, 10:26 PM
Tank Mike
Tank Mike's Avatar
Default little bit of a running problem after a ragging
I need a little help with this one.
if you give the car some stick and really welly it sometimes as it approches 5k it cuts out for a split second and come back to life again.
it runs perfect all other times
its only when you boot it really really hard.
its just like someone has turned off the igntion for a split second.
any ideas
Old 03-04-2008, 10:56 PM
rs_cos
3 door resto in progress
rs_cos's Avatar
what car is it mate?
Old 03-04-2008, 10:57 PM
rsnissan
rsnissan's Avatar
boost cut on the chip
Old 04-04-2008, 11:10 AM
Paul_RS
Paul_RS's Avatar
Could also be your engine loom multiplugs, mine used to cut our about 5K and by cleaning the plugs i eliminated to missfire!
Old 04-04-2008, 03:55 PM
Tank Mike
Tank Mike's Avatar
its a 4x4 saph.
it has an msd chip thats does something with the lambda sensor.
it peaks 25 holds 20psi
Old 04-04-2008, 06:16 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Are you sure it's not just a misfire?
Old 04-04-2008, 08:09 PM
Tank Mike
Tank Mike's Avatar
no its too big to be a missfire. its just as if the igiton goes off for a split second.
then it goes again.
i think its heat realated becuase its only when you really rag it.
Old 04-04-2008, 08:52 PM
BIL N KEL
BIL N KEL's Avatar
would deffo say you're hitting boost limit
Old 05-04-2008, 12:30 AM
Paul_RS
Paul_RS's Avatar
Try the multiplugs too, use electrical contact cleaner on them, plug them in and out a few times then dry. Its a cheap and easy thing to try before you start chasing other faults!
Old 05-04-2008, 09:57 AM
Tank Mike
Tank Mike's Avatar
thanks mate, i'll give that a go
Old 05-04-2008, 10:01 AM
whitley
whitley's Avatar
Location: Aberdeen where men are men and sheep are scared!
my series1 used to do it aswell it was runnin a bit rich but it was just once she was hot and u put the throttle on really hard at about 5k rpm it would cut out then come back 2 life,was just the car hitting its boost limit because i was running a standard actuator,so i would say up rate your actuator n get her set-up
kosienutter
31
22-08-2015 09:55 AM
nick8saff
16-08-2015 05:35 PM
Zoggon
10-08-2015 10:39 AM
ginger1979
31-07-2015 09:56 PM
Quick Reply: little bit of a running problem after a ragging
