boost controller
Old 31-03-2008, 08:48 PM
Sta1n1
Sta1n1's Avatar
Default boost controller
Hi, was wondering what type of boost controller people run with ? Been hearing shit about this bleedvalves and since I have one I must say I agree, the boost wont hold it self stable yes so, give me some information ? I dont like it when the boost peaks at one point then drops down a bit ...
Old 21-04-2008, 08:02 AM
Sta1n1
Sta1n1's Avatar
nobody who can help me ? I`ve been thinking about a electronic boost controller ? Is this just plug and play on a cosworth ?
Old 21-04-2008, 10:41 AM
reisskahn
reisskahn's Avatar
Hi mate dont think many or if at all any cosworth owners run an electronic boost controller. Usually see them on the japanese cars..
Plus its not a plug and play option its needs setting up once fitted and depending on the controller it isn't really a simple thing to do.
Hope that makes sense
Old 21-04-2008, 02:27 PM
Yura
Yura's Avatar
I run whith simple GREDDY BSpec2. Easy to install, easy to adjust, small and has some useful functions - easy switch between two preset mods, keep in mind peak boost, show last boost some seconds after you close the throttle, also you can increase boost at hi rpm if your boost droped at hi revs.
Old 21-04-2008, 04:33 PM
LHD220Turbo
LHD220Turbo's Avatar
Sta1n1, this might help you, what car is it on?
https://passionford.com/forum/showth...ost+controller
Old 21-04-2008, 07:45 PM
Sta1n1
Sta1n1's Avatar
thanks, Ive just bought an GREDDY BSpec2. Its going on a sierra cosworth 4x4, I had a bleed valve earlier but I ended up with one heck of a boost peak, so was hoping to get rid of this with an electronic boost controller ?
Old 21-04-2008, 07:50 PM
LHD220Turbo
yes, a boost controller is much more reliable & better than a bleed valve
Old 21-04-2008, 07:56 PM
Sta1n1
Sta1n1's Avatar
great then I hopefully would be happy with this, with my bleed valve it peaked at 1.8 bar and got stable at 1. bar...Thats a pretty big gap...
Old 21-04-2008, 08:13 PM
LHD220Turbo
it will probably need setting up with the boost controller
timsrs
13-11-2018 11:48 AM
Mark RS
12-10-2015 06:01 AM
fordrallycar
30-09-2015 07:57 PM
stevecfrst1
30-09-2015 05:18 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: boost controller
