Engine resonance at 4000 rpm
I hope this is not a stupid question but we have 2 Cossies (4x4) and they both have this resonance at 4000, is this a characteristic of a Cossie or can something be done about it?
Has your actuator got the correct pre-load on it as mine didnt and the wastegate flap was causing noise which travelled down the exhaust.
0-60 in 17 seconds (eek)
There's a nut, washers and bolt under the throttle body to secure the tb to the engine mount (or near enough), the washers are "special" dished washers, maybe they're a little slack
had the same sort of noise, vibration on mine turned out that the turbo was out of balance ( had a distorted fin on the compresser side ) got the turbo rebuilt and was fine
Zoggon
10-08-2015 10:39 AM
