still tappy after changing lifters???
Old 28-03-2008, 06:03 PM
turblower
turblower's Avatar
Default still tappy after changing lifters???
hi there peeps,i wonder if anyone knows the problem i got?
i changhed the hydraulic lifters and oil and is still doing a weird tapping noise,it does it on idle when its cold,when u rev the engine a bit the noise goes but when it comes back to idle it starts doing the noise again,
weird thing when the engine warmps up the noise goes.
i got the lifters from matt lewis and the oil is good silkolene 10-50
what u reacon peeps beacause its doing my headin.
please help me..................................
Old 28-03-2008, 06:06 PM
Si B
2Evos & 1 Escort Van :-)
Si B's Avatar
Can take a while sometimes for the lifters to fully fill up with oil - I've had a noisey lifter that lasted I'd guess a good 30 mins of use. Other times they've gone quiet within minutes.
Si
Old 28-03-2008, 06:11 PM
COCHYN
COCHYN's Avatar
Its a Ford
Old 28-03-2008, 07:06 PM
turblower
turblower's Avatar
well i left it running an took it out for a drive lastin about 1 hour all in all,but i started it in the morning an the noise is still their.
could it be the cams?
Old 28-03-2008, 07:17 PM
col cos1
col cos1's Avatar
dont wory about it,i did but it always soon clears up,my last ones took 1500miles
Old 28-03-2008, 07:41 PM
Moonstone Steve.
Moonstone Steve.'s Avatar
Check the timing and line the bottom pulley with the lug and pointer not the groove and pointer, when lined with the groove the valve can kiss the pistons and it will sound like tappet rattle.
Steve
Old 28-03-2008, 09:13 PM
turblower
turblower's Avatar
thanks guys,ill keeep on driving it rouns and hopefully the noise goes......
when yours was tapping,did the noise dissapear when u reved it up.
Old 28-03-2008, 09:23 PM
Moonstone Steve.
If its valve to piston contact it will stop once its made a big enough dent in the top of the piston i would check all timing is as above before driving any ferther
Steve
Old 28-03-2008, 09:57 PM
turblower
turblower's Avatar
hay really appreciate this info.....
if it was to be that will the noise go after the engine is warm?
Old 29-03-2008, 07:18 AM
It could take a few hundred miles to fully settle, mine did, despite the oilways etc being clean, as flushed out oilways etc.
My car still sounds cammy, but is actually(on mine) piston slap, as it's a bit tired 120,000 + miles now!!
Old 29-03-2008, 11:18 AM
TurboShed
Cossiemodo
TurboShed's Avatar
What oil are you using mate??
Old 29-03-2008, 01:03 PM
turblower
turblower's Avatar
using silkolene 10-50 guys,
hay tabetha,does the noise go after the engine warms up on yours?
Old 29-03-2008, 01:06 PM
turblower
turblower's Avatar
if it is piston slap,how can it be fixed?
Old 29-03-2008, 07:26 PM
mechanic28
mechanic28's Avatar
rebuild the engine!using 4x4 pistons or con rods cant remember which way round!but piston slap is nothing to worry about fella!persume yours is a 2wd?
Old 29-03-2008, 08:34 PM
turblower
turblower's Avatar
it's a 4x4.do u reacon it could blow up easy?
Old 29-03-2008, 08:37 PM
BigErn
BigErn's Avatar
little ends on the way out??? Worn cam profile??
Old 29-03-2008, 11:49 PM
mechanic28
mechanic28's Avatar
in all truth fella i would not worry bout it!unusual for a 4x4 to get pistonslap!but u have to remember its a cossie these are basic old things really and generally noisey old things when cold!give your tappets a chance to settle in!
Old 30-03-2008, 05:42 AM
My noise gets a lot less when warmed up but sounds like a tractor till then.
As said use of 4wd(tractor!!) pistons cures it mostly, but due to the inherant design there will always be a little bit when cold, but a lot more so on 2wd, the gudgeon was moved on 4wd to counter this.
Piston slap causes no harmful effects, and is just a characteristic rather than a fault.
Personally unless it is drinking oil(like mine!!) I would not do anything.
Old 30-03-2008, 09:54 AM
turblower
turblower's Avatar
thanks peeps really appreciate this again....
01-11-2015 06:53 PM
07-10-2015 12:56 PM
dojj
29-09-2015 10:32 PM
rsguy
44
29-09-2015 03:29 PM
marky_g
12-09-2015 04:26 PM
Quick Reply: still tappy after changing lifters???
