how much preesure should be....
Old 25-03-2008, 06:01 PM
cossiegreg1
cossiegreg1's Avatar
Default how much preesure should be....
in your header tank, mine seems to be squirting water out the header tank via the cap,im hoping its not the head gasket. any ideas?
Old 25-03-2008, 07:20 PM
Twellsie
Twellsie's Avatar
mine did this on the last two occaisions with the head gasket letting go
Old 25-03-2008, 08:12 PM
legend289
legend289's Avatar
I would think around 20 PSI absolute max, i would think there is a pressure rating on the cap somewhere, more likely to be around 15 psi. Get your local garage to poke their gas tester in the header tank with the car running to see if it sniffs exhaust gases in there.
Old 25-03-2008, 08:13 PM
rapidcossie
rapidcossie's Avatar
would say faulty cap or head gasket.
Old 25-03-2008, 08:15 PM
jemis
jemis's Avatar
Does it do it all the time.
Old 25-03-2008, 08:20 PM
CharlieSaff
CharlieSaff's Avatar
My Zetec Escort did this and it was headgasket
Get a check done on it mate
Old 25-03-2008, 08:28 PM
rinus_2005
rinus_2005's Avatar
Had that a couple years ago, i went back to the chap who sold my that alloy headertank. (which i only had fitted for a week) Told him his cap was a cheesy one. Without blinking he gave me a new one, but adviced me to have the engine checked. Turned out it was indeed the headgasket
Old 25-03-2008, 11:49 PM
philbert
philbert's Avatar
Default how much
I would say the rubber seal in the cap is gone, had this one before on a new engine build and cap was at fault put a little drop of oil on the new cap rubber and it should last a little bit longer alloy tanks seam to heat the rubber and make it pesrish
Old 26-03-2008, 03:28 AM
R5FORD
R5FORD's Avatar
check that there is actully a rubber seal in the cap.. and check it hasnt worn.. had the same problem on mine and it turned out it was the seal.
Old 26-03-2008, 06:02 AM
How high is the level when cold ?
I had a mondy whose level would settle about 1 1/2" BELOW the minimum all the time, topping up it just got rid of "extra" so just left it so I could see it 1 1/2" below min and it was fine, sold it to my dad told him NOT to top up so he tops up to the BRIM, one headgasket and plenty of arguments later the headgasket is fixed.
I would look at the cap seal first, if only because it is easier/cheaper.
Old 26-03-2008, 09:27 AM
cossiegreg1
its a ally header tank, i been filling water up to somewhere near max then its been spitting water out, to near the bottem. was going to keep an eye on it to see if it gets any lower.
i have an escort van and have swapped the cap with that, and its still the same.so i'll get a sniff test done!
Old 26-03-2008, 01:23 PM
AndyPen
AndyPen's Avatar
Afraid it doesn't sound good mate - good luck with the test!
Old 29-03-2008, 05:01 PM
groomers
groomers's Avatar
mine did this and it was the thermostat bit cheaper than a head gasket!
scoooby slayer
77
30-12-2009 07:30 PM
mgbrs
02-03-2009 04:40 PM
R5FORD
09-02-2009 12:44 AM
xr4x4rs
07-08-2007 12:53 PM
jpbaginski
31-07-2006 07:33 PM
Quick Reply: how much preesure should be....
